Running rich both banks - TCCoA Forums
 1Likes
  • 1 Post By Grog6
post #1 of 28 (permalink) Old 08-09-2016, 07:16 AM Thread Starter
I have read a number of posts in several threads trying to track down the source of my problem. I posted in an old 2008 thread with no response and another thread but it was suggested to start a new thread.
I have (2) 1997 birds with 4.6, one just turned over 200K and the other with 100K. The CEL came on the one with higher mileage with PO172 and 175 codes (rich both banks). Both short and long term fuel was high. My friend scanned and isolated several areas of possible concern. I replaced the EGR solenoid, checked and replaced several vacuum lines and replaced the ECT sensor as it was thought the engine was running too hot. After each replacement the CEL would stay offf for a short period but eventually came back on but did end up showing rich condition on Bank 1 only. Ran with AC on to keep cooling fans running seemed to help some but CEL is now back on. I read in one of the posts the IAC could be the culprit. The car runs good but the engine will surge at low speed and at idle (stopped for traffic light, etc) the engine speed will rev up several times especially in warm or humid weather. When shifting to park the engine will also rev up. These latter conditions have occurred since I got the car over 10 years ago. I have cleaned the MAF recently and IAC a while ago. Any suggestions
ranco is offline
post #2 of 28 (permalink) Old 08-09-2016, 07:55 AM
MAF sensor is in good condition? O2 sensor condition? How's fuel economy? Excessive black soot in exhaust?
post #3 of 28 (permalink) Old 08-10-2016, 06:31 AM Thread Starter
MAF appears to be in good condition. I have not inspected O2 sensors but scan data would indicate these are not a problem. Fuel mileage is down due to CEL and rich condition but not excessive plus adding the use of AC reduces mpg. No soot in pipes. Fuel trims were high b4 adjustments outlines previously and were reduced to normal but will spike when engine temp rises. Coolant is probably 4-5 years old and I tested with VOM but do not have data on what the resistance should be.
ranco is offline
post #4 of 28 (permalink) Old 02-23-2018, 09:43 AM
Wile E. Coyote Jr.'s Avatar
Hijacking this thread.
My car is running extremely rich. I even checked the cylinders and there was a puddle of fuel in each cylinder. All the spark plugs were covered too. Talking with the tuner who made my chip he said that it could be my MAF or the chip isnt making a good connection with the J3. So I swapped to my stock MAF and even a Mark 8 MAF I had sitting around and the issue persists. I noticed theres even a fuel vapor in the intake tube. I turned to Power Hungry Performance who had a how to on adding solder to J3 the connections to make a tighter fit so I did that. I even tried the chip on a second computer with the same calibration code as mine. The only difference that either made was a slightly better throttle response but its still dumping fuel. The engine has probably 30 minutes on it. The only other sensors I can think to change are the o2s which are brand new Bosch sensors but after that I can only think of the tune to blame. Whats done to my car is in my signature. The injectors arent leaking, I built up pressure in the system and used the camera to see any fuel coming from up top and couldnt, maybe that is a laughable way to do things. After about 15 minutes the pressure hadnt dropped in the system. Just trying to figure this out and Id like some help.
Stacy: 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Ellie: 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Wile E. Coyote Jr. is offline
post #5 of 28 (permalink) Old 02-23-2018, 11:49 AM
Try this: Put a NOID light on the injector, see if it's hot without the engine cranking or running.
94/95 ECUs had a problem with the injector drivers shorting, meaning that they ran 100% duty cycle. That was supposedly fixed by 1996, but ...
Of course, the obvious questions - 1: The tune is for a 30# injector, not the stock 19# or 24#, right? 2: For a 1996, why a chip? You can get a tune that uploads via the OBDII port instead of using a chip. 3: Have you tried data logging to see what the MAF, TPS, and injectors are doing?
Fuelly
RalphP is offline
post #6 of 28 (permalink) Old 02-23-2018, 12:10 PM
Banned
Just because your 02 sensors are new doesn't mean they are good. Twice had had bad 02 sensors out of the box.
Even the ones I just ordered for my m8 came with instructions telling me test them just encase,lol I thought that was funny and ironic .
94badbird is offline
post #7 of 28 (permalink) Old 02-23-2018, 02:18 PM
I went with a chip because it was a cheap way to make the car run until I could get it to a dyno tuner. So far I have been proven wrong. The tuner says it is tuned for the 30s and they are on the mod sheet I sent to him. He says he doesnt like the MAF that I am using, he made that very clear. He didnt give me a reason he just said he doesnt like it. I dont have any of the equipment to datalog and as of right now cant afford it. My EEC is an MBE2 and both had 1995 printed on the board. My car is an early 1996.
post #8 of 28 (permalink) Old 02-23-2018, 02:44 PM
You need a cheap datalogging setup. I've seen them at ~$20, the full sw is more...
There are a dozen OBDII datalogging apps; get a cheap bluetooth OBDII dongle that will work with your phone, and find out WTF is going on.
Take a quick look at GM's datalogging tutorial; everything is applicable, even if you don't use an xcal.
I have a wideband in the cars I'm tuning, 'cause I'm an idiot at times, and need a comparison to reality.
The stock sensors being pegged lean or rich don't tell you squat, lol.
Right now, due to some input, your O2's are screaming lean, covered in fuel. You need to know why.
Grog6 is online now
post #9 of 28 (permalink) Old 02-23-2018, 03:39 PM
S4gunn's Avatar
You can also measure duty cycle at the injectors on some multi-meters
Sears.com
I've done this on my tbird (pre-OBD2).
-g
http://goo.gl/csaet4
S4gunn is offline
post #10 of 28 (permalink) Old 02-23-2018, 03:50 PM
This presumes it's going closed loop; we don't know for sure he's running it long enough!
And if it's not going closed loop (and Torque Free and a ELM327 OBDII adapter) will tell him (and us!) if they're even being read.
Fuelly
RalphP is offline
post #11 of 28 (permalink) Old 02-23-2018, 03:54 PM
You absolutely NEED a way to datalog.
Grog6 is right; I used to use a (2013 vintage!) $75 ELM327 OBDII/Bluetooth adapter (currently they're more like under-$20) and a copy of Torque Pro (cost $5; they have a free variant) to monitor my 2000 Malibu.
I'd grab that, and possibly swap in some stock injectors, to make SURE it's not the tuning screwed up.
What MAF does he say to use? If a competent tuner says "I don't like that MAF", I'd listen to him; if you don't trust him that much, why are you letting him tune your car?
(Shucks, I tell people to talk to their tuner on picking cams / headers / gears / MAF / injectors ANYWAY; you want what they have a proven quality record with if you're using mail tunes.)
Fuelly
RalphP is offline
post #12 of 28 (permalink) Old 02-23-2018, 03:57 PM
I will look into finding a bluetooth OBDII plug thatll work; my phone doesnt seem to like using it. I know that the 4 wire o2s have a heater in them to try and bring them up to temp before the car starts, is there a possibility they arent warming up? Its been cold here and I havent run the car for more than hour total since its been done, not really bringing it up to temp.
post #13 of 28 (permalink) Old 02-23-2018, 04:02 PM
I dont know him. I got an SCT chip off of SCP and I have been talking through Bill. He wants me to get a 76mm MAF with interchangeable sample tubes. Im assuming he wants me to use the stock sensor since SCP doesnt sell sensors with the housings.
post #14 of 28 (permalink) Old 02-23-2018, 04:47 PM
That sounds like a C&L MAF, I thought those were a bitch to tune with because they had no transfer function.
post #15 of 28 (permalink) Old 02-23-2018, 05:11 PM
It is a C&L. I didnt know they were hard to tune, raises a few questions to me though.
On a different note I downloaded an app and ordered a Bluetooth plug, hopefully I can start to get an understanding of whats going on.
post #16 of 28 (permalink) Old 02-23-2018, 05:26 PM
Yeah. That sounds more like a sales ploy than anything. Your MAF has a known transfer function, which the tuner can simply drop into the file. The tuner should love that, not hate it.
post #17 of 28 (permalink) Old 02-23-2018, 06:42 PM
...I know that the 4 wire o2s have a heater in them to try and bring them up to temp before the car starts, is there a possibility they arent warming up? ...
The heater is to maintain temp, not preheat anything. It keeps it at temp; O2 sensors don't really start to work unrtil ~2 minutes after start, and it assumes you're driving.
...I got an SCT chip off of SCP and I have been talking through Bill....
Originally Posted by racecougar View Post
Yeah.
...That sounds more like a sales ploy than anything. Your MAF has a known transfer function, which the tuner can simply drop into the file. The tuner should love that, not hate it.
The tuning process is not that difficult; many have mastered it.
But there's always "The Rest of the Story".
I bought the SCT PRP because I'm an anal-retentive, Type-A asshole, with major delusions of grandeur; after YEARS of incremental changes, I THINK I know how to tune my cars.
Don LaSota could have written ALL my tunes in an afternoon, lol.
He would ask for datalogs to fine tune it, but he's a Master.
RalphP likes this.
Grog6 is online now
post #18 of 28 (permalink) Old 02-23-2018, 08:13 PM
Im figuring now that the o2s do nothing for the first few minutes its either going to be the tune, the MAF, or the possible short in the EEC causing the injectors to run at 100% DC (which I am skeptical of that being the issue, one came out of my car and was perfect while the other one again came from a running car). I will check for the short first, then swap over to my stock 19s tomorrow to see what happens. Ill have more than a few words to say if the car magically starts working again with the 19s.
post #19 of 28 (permalink) Old 02-24-2018, 11:41 AM
If that fixes it (swapping to 19# injectors), then we know for a fact that's a bad tune for you.
Time to either figure out how to tune yourself (hint: LaSota's book and Banish's books are HIGHLY recommended!) or just bit the bullet and talk to LaSota.
Fuelly
RalphP is offline
post #20 of 28 (permalink) Old 02-24-2018, 12:31 PM
Just ran it on 19s and it barely keeps its idle. Without me touching the gas it jumps between 500 and 2000. It sounds horrible. The tune is working in some form. Another thing I noticed was that when I pulled the 30s out, the caps stayed in the injector well. They are billet bodies with the nozzle built in so I dont think it could mess with the spray pattern but thats something to note. I couldnt find a NOID light that doesnt have to be shipped so I didnt check for the 100% DC short today. I am leaning towards either the short or the o2s. I noticed that the spark plug and the cylinders Were still wet with gas after the 19s were installed so I am concerned about either the timing or an engine ground being bad. But it also make me lean more towards the o2s. Really hoping they arent bad since they werent cheap and I forget how long the warranty was
post #21 of 28 (permalink) Old 02-24-2018, 01:27 PM
What I would actually do:
I'd go buy a 6V to 9V flashlight lamp, solder some leads to it, and make a 'noid light.
You can tap into the leads, leaving the injector hooked up.
Even a Meter-type voltmeter can be used; you just have to recognize you're seeing a 'pulse-width-modulated' 12V signal.
It will read the average voltage; probably ~3v at idle, and closer to 12V at wot.
You don't even have to disconnect the injector.
Don't do wot with one injector off; it's not good.
A DVM won't read a PWM signal unless it has a setting for that; if it does, it will read 0-100%. (It doesn't sample fast enough)
Idle will be a low percentage, and wot will be close to 85%.
I heard this from a buddy; guess what he drives.
Well, If you're completely insane, you could:
disconnect the coil packs,
Pull the fuel injector rail up, leaving the injectors in the upper rail
Have someone try to start it
See what the spray pattern looks like, while spraying gasoline vapor all over.
I would absolutely not recommend that. (Don't try this at home, REALLY.)
But if anyone ever does this: Take pix! Your Darwin award can't be sent out without pix.
Plus, it will blow the injectors out if they're not retained.
(I know a mustang guy who swore he could see the pattern and know the flow was right. )
Grog6 is online now
post #22 of 28 (permalink) Old 02-24-2018, 01:43 PM
If you ran it less than 2 minutes, it wasn't the O2s.
The ECU won't even sample them until it's run for a bit.
Besides, if it WERE the O2s, the ECU would have demanded more injector to keep the idle up.
You've got something else wrong; I'd check the NOID light on the injectors, possibly with it not running (if the ECU has shorted drivers, they'll be on even with the motor NOT running.)
Fuelly
RalphP is offline
post #23 of 28 (permalink) Old 02-26-2018, 08:01 PM
Well, its fixed. And how I fixed it was pulling the chip out of the computer and plugging in my stock 70mm MAF with the 19s. No longer dumping fuel, has a great throttle response and sounds how it should. I am in the works to have the chip sent back to see if there was something wrong with the chip physically or if there was some sort of mix up in the tune itself. Part of me wants to just tell them to keep it and use the money to get it dyno tuned, but the other part of me wants to see if they can fix it.
Funny thing is that with out the chip the engine still has no code still, not even for the EGR or the rear o2s even though both are removed. And yes the car warmed up today, ran it for about 20 minutes and even took it for a drive, enough to show codes.
post #24 of 28 (permalink) Old 02-26-2018, 08:11 PM
20 minutes wont do it; look up "Ford Drive Cycle"
Ford Motor Company Driving Cycle
You can use a Xcal2 to reset the computer, or try to start it after removing fuse 15 in the underhood fuse holder, Or disconnect the battery for 30 minutes...
The key things:
Car must be warmed up. >2 minutes of drive time to start process. I'd think more towards 10.
They need to be done in sequence; if not, some tests will repeat when a previous step is fulfilled.
Here's what I personally do.
I start the car, go inside, make a glass of tea, and go get in the car.
Drive out of the hood, hit the 4 lane.
drive ~4 miles, to the split.
Turn around, and drive the other way, past the house, thru town.
Stop and go for ~10 non-equally spaced redlights.
Drive to wal mart, ~10 miles, 60-70mph, depending on cops.
Park car, go shop for a bit, drive home.
The CE light will hit about the time I get to this one intersection, if one is going to go.
Grog6 is online now
post #25 of 28 (permalink) Old 02-26-2018, 10:06 PM
Banned
Glad it's fixed ..
Moral of the story should be..
" I shoulda called Don"
post #26 of 28 (permalink) Old 02-26-2018, 10:14 PM
Well, its fixed. And how I fixed it was pulling the chip out of the computer and plugging in my stock 70mm MAF with the 19s. ...
Yeah; you really need someone competent to write tunes for you.
I write my tunes now, with substantial guidance from Don, but can't blame him for my fails; I only read his book, after all.
Originally Posted by 94badbird View Post
Your nonsensical post went away as I quoted it. Pity.
Grog6 is online now
post #27 of 28 (permalink) Old 02-28-2018, 02:57 PM
So with data logging my car I found this out. The fuel trim for bank 1 is -18.75% while bank 2 is 38.28%. I have no lean or rich codes and the DL shows that my AFR stayed between 14.5 and 14.9. Why is there such a difference? Is there a way I can fix this? I also made a WOT pull and everything seemed stable. My MAF stayed at around 12.27 g/s but jumped up to 157.55 g/s on my pull. Idk what that means to be honest. The engine seemed shakey getting to 2500 but buried the needle after that.
... I also had it record Engine HP (at the wheels). Now I know it isnt accurate but the point where it started to crest was right at 300, so I do currently have a smile on my face despite my ignorance.
post #28 of 28 (permalink) Old 02-28-2018, 05:00 PM
That's not right; that's a pretty big imbalance.
I'd swap the o2 sensors first, left to right, see if it follows it.
If it's not that, I'd swap the injectors left to right.
If it stays the same, I really don't know what it could be.
Do you have a misfiring cylinder, or a plug fouled from the gas dumping?
Grog6 is online now
