Info needed about 94 cams - TCCoA Forums
 9Likes
  • 2 Post By T6Rocket
  • 1 Post By XR7-4.6
  • 1 Post By T6Rocket
  • 1 Post By XR7-4.6
  • 2 Post By Woodman
  • 2 Post By Draetech09
post #1 of 22 (permalink) Old 12-02-2016, 10:19 AM Thread Starter
Banned
I am thinking about doing a pi cam swap but does my 94 lx has bolt on cam gears? I did it in my old cougar but dont want to go through all the work if they are solid cams.
I like the short cut route.
94badbird is offline
post #2 of 22 (permalink) Old 12-02-2016, 10:31 AM
Bolt-on. But PI cams still won't work in 94-95 heads
post #3 of 22 (permalink) Old 12-02-2016, 03:21 PM Thread Starter
Banned
Why not? I thought 94 95 heads were same as 96 97, just different intake
post #4 of 22 (permalink) Old 12-02-2016, 04:12 PM
T6Rocket's Avatar
In before the lecture.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 22 (permalink) Old 12-02-2016, 04:30 PM
The ports are the same, but the valve spring installed height is different. The added lift of the PI cams will cause coil bind in the 94/95 NPI heads.
post #6 of 22 (permalink) Old 12-02-2016, 04:47 PM
The 96 heads were updated with beehive springs and deeper seats, which accommodate the PI cams(PI heads carried over these changes), 95 and earlier heads have shallower seats and shorter springs, so any cam with a lift higher than the factory npi cam will cause the coils to bind. Only way around it is to swap heads to 96+ npi or PI, or swap motors.
Beat me to it. The ports are actually different though, the shape at the flange is the same and the difference in performance is negligible, but 91-95 heads have a kink inside the port like PI heads do, rather than the straight tunnel-port like shot to the valve like the 96+ npi heads.
post #7 of 22 (permalink) Old 12-02-2016, 07:48 PM Thread Starter
Banned
Well that sucks. My car is stuck as modded as I can get it then,except for nitrous I would be scared to procharge it then,
Maybe its time to save for a complete pi engine .
post #8 of 22 (permalink) Old 12-02-2016, 08:36 PM
Woodman's Avatar
Why not get some PI heads out of a junkyard? Any Crownvic 2002+, 1999-04 Mustang GT's, Not sure on the year but 4.6 Ford F150's or Explorers, all use the exact same heads and cams.
Woodman is offline
post #9 of 22 (permalink) Old 12-02-2016, 09:13 PM
Not exactly the same, 99-00 Mustangs and many of the truck 4.6s use the Windsor cast heads, so you're stuck with the windsor style valve covers with the pass side oil fill - which IME is not friendly with GT intake tube and A/C line fitment.
Woodman likes this.
post #10 of 22 (permalink) Old 12-02-2016, 10:27 PM
Woodman's Avatar
True, I didn't think of that.
Woodman is offline
post #11 of 22 (permalink) Old 12-03-2016, 06:15 PM Thread Starter
Banned
Ha head swap is something years down the road for me, thispoint I can't afford this after spending all I did replacing glass and finishing my 98 style performance upper end....I would trade never used 75mm throttlebody with all mounting hardware and a dual programmable superchips eliminator ecu chip. Trade them for a pi intake and valley tube and nipple and alternator bracket.
Id sell the items too, also have my stock 95 intake a,d plenum and throttlebody , fuelrail and injectors. Good for a nitrous car.
post #12 of 22 (permalink) Old 12-03-2016, 11:25 PM
Mgino96tbird46's Avatar
Not to mention, blown out spark plugs. lol
I'd look for heads with the full spark plug threading.
Mgino96tbird46 is offline
post #13 of 22 (permalink) Old 12-04-2016, 04:46 PM Thread Starter
Banned
Pi heads wouldn't be out the queston but last pi swapped car I had the gains were barely knowticable so too much work for little gains. Plus i plan on getting rid of this car for a96to98 mark8 or 32v mn12 or even a 96 plus mustang gt
post #14 of 22 (permalink) Old 12-04-2016, 05:46 PM
Woodman's Avatar
As long as you torque them to spec (14 to 17 lb ft, not the old school Tight plus half a turn), you'll never have a blowout.
Woodman is offline
post #15 of 22 (permalink) Old 12-04-2016, 05:47 PM
Woodman's Avatar
Was it tuned?
I had a bone stock 4.6, and currently a PI Swapped one that is being upgraded to an Explorer block, ported heads, S2 cams, Kooks, etc.
There was a significant performance difference between the standard NPI and the PI swapped motor.
Woodman is offline
post #16 of 22 (permalink) Old 12-05-2016, 06:53 AM Thread Starter
Banned
Ya it was tuned.it was if I remember correctly only like 15.3 in the 1/4 mile and stock it was 15.8 and with the pi stuff it also had an exhaust and 70mm intake setup
post #17 of 22 (permalink) Old 12-06-2016, 08:31 AM
what I noticed with my cougar with the pi intake and heads it seemed to waken up some. I also going to beef up the trans to help it shift better to match the engine. granted automatics never perform as well as a 5 speed. but I know the mustang i have is also a ramero as well i know they came with both ramero and Windsor which makes it a little tricky on finding some ramaros off of one. but if you find a app on your phone that can run a vin on a car that you are going to pull the heads off of or find a u pull it that can spusificaly tell you what type of engine it has that would be a bonus. the u pull it i go to once in a while they actually get the spusifics of there cars. that's a rarity
95mercxr7 is offline
post #18 of 22 (permalink) Old 12-06-2016, 08:36 AM
T6Rocket's Avatar
I would hope that PI heads and intake should wake it up some!
What is a ramero? A Camero with ram air?
Al
Draetech09 likes this.
Previous Fords:
T6Rocket is offline
post #19 of 22 (permalink) Old 12-06-2016, 01:08 PM
Originally Posted by T6Rocket View Post
What is a ramero?
Al
spusificaly?
post #20 of 22 (permalink) Old 12-06-2016, 02:11 PM
Woodman's Avatar
Well, you're talking 30 or so more rear wheel hp with a good tune, so without much else (torque converter and rear gears) I wouldn't expect it to go dramatically faster. I believe mine was somewhere in the high 14's with full 2.5" exhaust, Mark VIII TC and 3.73:1 gears while under Traveler's ownership. I expect a little more out of it now with the full PI engine, ported heads, stage 2 cams, 75mm throttle body and accufab inlet elbow, and a good tune, but I don't know where that will put me in the 1/4, I'm not that into times.
All I car is that it runs and feels fun.
CDsDontBurn and KEVIN8989 like this.
Woodman is offline
post #21 of 22 (permalink) Old 12-06-2016, 10:27 PM
Draetech09's Avatar
spusificaly?
Al
Lol I knew what he meant but I figured I wouldn't be the only one to notice. I'm still cracking the fuck up!
Woodman and drew96dawg like this.
If you Fail to plan, then you plan to Fail!
I'll forever bleed Ford Blue
Drae
Draetech09 is offline
post #22 of 22 (permalink) Old 01-03-2017, 01:58 AM
twin turbo 281's Avatar
I had put stage 2 npi comp cams in my bone stock 95 motor. They were stock lift with a 230/236 I think duration. Made it about 50K beating it hard until a valve spring broke and valve head snapped off and crumbled a piston and the rod blew out the cylinder wall.
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
