Exhaust leak in valves - TCCoA Forums
post #1 of 5 (permalink) Old 12-29-2016, 09:17 PM Thread Starter
donate12's Avatar
96 4.6L - I just replaced my valve cover gaskets (and grommets) and there appears to be exhaust leaking into my passenger side. Driver's side looks fine. I assumed this was a sign of bad valve seals. However I realized tonight that I have been hearing an exhaust leak on that side and assumed it was the manifold gaskets. So...would that sound be the exhaust leak from bad valves seals or do I potentially have coincidental issues?
donate12 is offline
post #2 of 5 (permalink) Old 12-29-2016, 09:49 PM
It doesn't really work that way. The exhaust isn't under enough pressure to leak past the valve guide and seal. What did you actually see under the valve cover?
MadMikeyL is online now
post #3 of 5 (permalink) Old 12-30-2016, 12:30 AM Thread Starter
donate12's Avatar
Basically carbon deposit. Dark and dry. Like you would see in exhaust. There was nothing like it on the driver's side.
It does have +200k miles on it...
donate12 is offline
post #4 of 5 (permalink) Old 12-30-2016, 08:28 AM
Could be something like a PCV stuck open or a malfunctioning EGR/DPFE.
I assume you have no fault codes?
mustang46kid is offline
post #5 of 5 (permalink) Old 12-30-2016, 12:26 PM Thread Starter
donate12's Avatar
No fault codes. I did have a fault code for low voltage on the DPFE for a while. But cleaning up the EGR system cleared that. PCV is good and Motorcraft. Replaced them fairly regularly. I've had the car for 18yrs and knew the original owner so I know its full maintenance record. I spoil it there since I am slightly abusive to it
donate12 is offline
