High pitched whistling sound - TCCoA Forums
post #1 of 11 (permalink) Old 06-30-2017, 09:55 PM Thread Starter
30thAnniversaryCat's Avatar
I get a high pitched whistling sound when I first start the engine every day and after it has been parked for several hours, which lasts several minutes. It doesn't vary much w/RPM or car speed. Seems to be at passenger side front of engine. No obvious problems w/steering or charging. More noticeable since blazing hot TX heat started. Any thoughts are appreciated.
30thAnniversaryCat is offline
post #2 of 11 (permalink) Old 07-01-2017, 08:09 AM
My '95 4.6 was doing that from around 2015-2016. I couldn't find it, thought it was temperature related. Now that you mention it, I don't think I've heard that noise since I cleaned out the EGR tube back in January.
Jim3inVirginia is offline
post #3 of 11 (permalink) Old 07-01-2017, 06:09 PM
gordonm1's Avatar
Rubber hose to ear or stethoscope(not sure don't own one) would help isolate the area.
High pitch, first thing to my mind is belts and pulleys and next is A/C compressor.
gordonm1 is offline
post #4 of 11 (permalink) Old 07-02-2017, 10:54 AM
Rayo's Avatar
Check your vacuum lines..Especially the one going to the PCV valve..
If there's a hole in one of those vacuum lines, they can make a whistling sound..
1991 Ford Thunderbird Sport
Rayo is offline
post #5 of 11 (permalink) Old 07-02-2017, 10:44 PM Thread Starter
I sprayed some WD-40 on the serpentine and the sound stopped. It may be that (it's about 5-6 years old). What do you think?
post #6 of 11 (permalink) Old 07-03-2017, 02:43 PM
ikutoisahobo's Avatar
Could possibly be the EVAP valve system, that usually operates on engine start up, could be the valve is obstructed in a way that causes it to whistle lol?
ikutoisahobo is offline
post #7 of 11 (permalink) Old 07-03-2017, 04:29 PM
Idler pulley. Try replacing the idler pulley or the belt tensioner that MCM51 mentioned. You'll probably also want to replace the belt.
If you can't trace it to a vacuum leak look at the pulleys.
#1 is the Idler pulley
#2 is the alternator
#3 is the other Idler shown on the right above
#4 is the Power Steering pump
#5 is the water pump
#6 is the crank
#7 is the tensioner pulley
#8 is the AC compressor
post #8 of 11 (permalink) Old 07-03-2017, 07:23 PM
You tell us what to think: does it still whistle from a cold startup?
post #9 of 11 (permalink) Old 07-03-2017, 09:56 PM
S4gunn's Avatar
WD40 is a solvent and NOT a lubricant.. and won't be doing anything rubber any favors.
You should spray silicone instead.
-g
http://goo.gl/csaet4
S4gunn is offline
post #10 of 11 (permalink) Old 07-04-2017, 12:30 PM Thread Starter
Yeah, whistle came back first start the next day
post #11 of 11 (permalink) Old 07-04-2017, 03:29 PM
Tbird Bob's Avatar
Maybe your car thinks you're sexy.
Tbird Bob is offline
