P0430 and O2 compatibility? - TCCoA Forums
 1Likes
  • 1 Post By T6Rocket
post #1 of 7 (permalink) Old 07-01-2017, 02:29 AM Thread Starter
I've been fighting this one for a while. Cleaned the MAF and did not help.
Tech mentioned something about the wiring to one of the cats when my daughter took it somewhere to have it looked at.
I have a new Motorcraft DY761 sensor but it is listed as a "front" or upper unit. I want to swap the downstream sensor as that seems to be more suspect from what I have read in other posts....
However the Motorcraft DY1086 is listed as the proper unit.
Only difference I can physically note is the length of the wire pigtail on the DY1086 may be shorter.....
Other units are listed as "either"....but I know Ford is good for changing something like the paint color which changes the application.....
Anyone have any experience with swapping O2's front to rear like this? Would save me some beans if this one will work!
Thanks!
Steve
fastmerc is offline
post #2 of 7 (permalink) Old 07-01-2017, 06:21 AM
The difference is in the location of the little alignment tabs. If you want to swap a front sensor for a rear, you have to cut that little tab off. That being said, a p0420 or p0430 code means your cat is bad, plain and simple.
post #3 of 7 (permalink) Old 07-01-2017, 10:51 AM Thread Starter
Roger that. Since I have the O2 sensor in hand....and in many cases it appears that a new sensor has resolved the 0420/0430 problems, I'd like to try that first rather than the hassle of swapping a cat.
Thanks!!!
Steve
fastmerc is offline
post #4 of 7 (permalink) Old 11-06-2017, 12:25 AM
The 1996 Tbird 4.6 that I bought about 5 years ago had a p0430 code. The last owner sold it thinking it needed cats and in Cali...cats are expensive.
I swapped in a rear O2.....never saw the light again. Bought that car cheap, gambled and won.
Max
2014 Chevy SS
1995 T-Bird LX 4.6
1994 T-Bird LX 4.6
2014 Chevy SS Sedan
2013 Camaro SS
2009 Dodge Charger Daytona
1975 Oldsmobile Delta 88 Royale Convertible 455.
Smkn600ctd is offline
post #5 of 7 (permalink) Old 11-06-2017, 05:40 AM
Bird-Aholic
Natesriv's Avatar
I sprayed tons of MAF cleaner on my 5.0 to stop it pinging...did squat. Only solution was a brand new MAF. Stuff gets old, coatings wear off...
Just FYI..
God created Arakis to train the faithful... One cannot go against the word of God.........
Natesriv is offline
post #6 of 7 (permalink) Old 11-06-2017, 08:08 AM
T6Rocket's Avatar
Just FYI..
I'm going to refer people to this post when they start getting crazy about spraying the MAF all the time. I have had two of them go bad not long after spraying them with the correct cleaner. May have been a coincidence, but I would not bet that way.
If a paper filter was always used, you could almost go the life of the vehicle without ever needing to spray one, especially on the cartridge style MAF they used in our 2004 CVPI. Yet guys on the Crown Vic forum talk about spraying the MAF all the time. The way it's positioned in the air stream, it would take 300k miles to get dirty.
Always look at it with a magnifying glass before spraying.
Al
Tbird Bob likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #7 of 7 (permalink) Old 11-07-2017, 05:59 AM
Bird-Aholic
Natesriv's Avatar
Just paper for me. None of that oiled filter stuff.
Natesriv is offline
