Looking for 350-400 rwhp - TCCoA Forums
 16Likes
post #1 of 76 (permalink) Old 08-10-2017, 12:47 PM Thread Starter
Jon Hall's Avatar
Hello,
So I have done a little research into buildiing a motor for these horsepower numbers searching other forums, mostly mustang, but wanted to get your guys imput. I will leave the question pretty general. What is the best way to get that kind of power in our cars without putting forced induction on it. Can this be done with heads, exhaust, internals, and the like? Also I am in cali so I have smog to deal with. Anyone in cali that has done something like this that is good to go through smog as well?
Jon Hall is offline
post #2 of 76 (permalink) Old 08-10-2017, 12:54 PM
ikutoisahobo's Avatar
Not on a 2V. Forced induction is the way to go on a 2V. Even a 4.6L 4V it's hard to get those 350-400rwhp numbers without forced induction. Those are really high numbers for a NA motor, because you're talking about 450 hp at the crank which is more than what even a new Mustang puts out with a 5.0, 4V, variable valve timing and so many more innovations.
Better to plop down 3k on a supercharger setup, it's the only way to go for those kinds of numbers.
ikutoisahobo is offline
post #3 of 76 (permalink) Old 08-10-2017, 12:54 PM
It won't happen NA with the 2V, what you need to even get 300 at the wheels certainly won't pass smog. Save up for a blower and take it off during inspections.
Originally Posted by ikutoisahobo View Post
Not on a 2V. Forced induction is the way to go on a 2V. Even a 4.6L 4V it's hard to get those 350-400rwhp numbers without forced induction. Those are really high numbers for a NA motor, because you're talking about 450 hp at the crank which is more than what even a new Mustang puts out with a 5.0, 4V, Direct Injection, and so many more innovations.
The 5.0 uses port injection, only the newest 2018 is getting dual(direct/port). The VVT plays the biggest role in the 400+ numbers.
post #4 of 76 (permalink) Old 08-10-2017, 12:58 PM Thread Starter
Jon Hall's Avatar
What kind of hp can stock internals take?
And lets say I do heads, nothing crazy just a little improvement, and internals that should not mess with smog if I take the supercharger off during smog testing correct?
Jon Hall is offline
post #5 of 76 (permalink) Old 08-10-2017, 12:59 PM
Thunderstruck95's Avatar
Plan on getting a set of Trick Flow heads- then add in what you can afford.
Whats your budget? And why stay NA?
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #6 of 76 (permalink) Old 08-10-2017, 01:00 PM Thread Starter
Jon Hall's Avatar
What is it that really messes up the smog. Would cams do it?
Jon Hall is offline
post #7 of 76 (permalink) Old 08-10-2017, 01:00 PM Thread Starter
Jon Hall's Avatar
I just like the idea of all motor. But if thats not possible I dont mind the blower.
As far as budget 3-5 grand. Of course cheaper if possible, but I dont mind spending the extra money for reliability. I want reliable power.
CDsDontBurn likes this.
Jon Hall is offline
post #8 of 76 (permalink) Old 08-10-2017, 01:06 PM
Yes, you'll never pass the sniffer test with lumpy cams, and additionally you'll need longtube headers(not shorty or midlength) to take advantage of the scavenging the cams allow, and there is no way those will pass CA smog, exhaust alterations before the cats are a BIG no no.
The internals generally seem to be able can handle just up to 400 rwhp on boost before connecting rods perforate the block, 350ish is definitely safe and reliable. You'd want two tunes, one a NA tune for smog purposes, and another one with the supercharger installed.
CDsDontBurn and Jon Hall like this.
post #9 of 76 (permalink) Old 08-10-2017, 01:41 PM
r429460's Avatar
My junk makes 348 at the wheels @ 6500rpm, with VP E-85.
But it has a big cam, big intake, big compression, big heads and big cubes.
Pump E-85 for fuel. Street driven, still. But why?
Any more HP and you lift the engine into a higher rpm range, that I was trying to stay out of. Trick Flow had an advertisement in Race Pages, (the NMCA magazine)
that 5.3L, 4.6 engine made 518 HP and 417 ft/lb torque @ 7000 rpm.
This probally will not pass a smog check.
I'll try to post the ad on the TCCOA facebook page.
Woodman and CDsDontBurn like this.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #10 of 76 (permalink) Old 08-10-2017, 02:34 PM
Here-
Third Ford Burden likes this.
1995 T-Bird.
post #11 of 76 (permalink) Old 08-10-2017, 02:38 PM
OOOhhh! Impresive.
Nice 3" headers. Wow that's a lot of flow.
post #12 of 76 (permalink) Old 08-10-2017, 03:39 PM
If Oscar gets his heap together and on the road we may see about the best an N/A 2v 4.6 with PI heads has to offer...
post #13 of 76 (permalink) Old 08-10-2017, 04:24 PM
r429460's Avatar
Thanks for pulling up that ad.
GM's HP and torque should be higher and at a higher RPM.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #14 of 76 (permalink) Old 08-10-2017, 04:25 PM
S4gunn's Avatar
CPSLS36LMAN Chevrolet Performance LS3 T56 Manual 2WD Connect & Cruise
50 state legal conversions are possible into 95 or older cars.
It's only money.
-g
http://goo.gl/csaet4
S4gunn is online now
post #15 of 76 (permalink) Old 08-10-2017, 06:51 PM
Just put a 3.5 ecoboost and a t5060 in it.
It's pretty much a direct swap. All you have to do is custom fab everything. While you're at it please make a good write up so I can do it next.
Woodman, CDsDontBurn and jayden like this.
bulldog is offline
post #16 of 76 (permalink) Old 08-10-2017, 10:14 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
OOOhhh! Impresive.
What you been smoking Monkey? 3" inch exhaust not 3" headers lol! Besides that's a nearly 50 cubic inch bored and stroked motor over a 4.6 so it should do something.
One bad ass set of cams in it too.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
post #17 of 76 (permalink) Old 08-10-2017, 10:29 PM
I was with trunk monkey- I figured they were using 3" collectors.
1995 T-Bird.
post #18 of 76 (permalink) Old 08-10-2017, 10:33 PM
1MTNCAT's Avatar
They are 1 5/8 headers and may be 3" collectors. Then a 3" exhaust. They sure aren't 3" headers.
Regardless it made very good power.
Was that in a Mustang??
Steve
1MTNCAT is offline
post #19 of 76 (permalink) Old 08-10-2017, 10:37 PM
1MTNCAT's Avatar
LOL!! I'll probably never see it ROFL!!!
I've done had one heart surgery and another associated surgery and have yet to see his done and mine's almost ready.
It would be interesting to see though.
Steve
1MTNCAT is offline
post #20 of 76 (permalink) Old 08-11-2017, 10:24 AM
I'll never tell ya what I've been smoking
Yea, yea, you know what I meant ... 3" exhaust. My bad. I didn't type it that way.
But yea, wow, those are beefy cams.
Theirs: .625/.625 lift, 252/256 .050 duration, 113 LSA
1MTNCAT: .550/.550 lift, 234/238 .050 duration, 113 LSA
Mine: .536/.540 lift, 228/235 .050 duration, 114 LSA
For yours I pulled the cams from your gallery/garage and looked up the Comp Stage 3 Stats. http://www.compcams.com/Company/CC/c...?csid=969&sb=0
The difference is you guys are N/A, I've got a blower.
post #21 of 76 (permalink) Old 08-11-2017, 10:35 AM
iamcaper's Avatar
https://youtu.be/PYRgbNCusBE
here is what 367 wheel horsepower looks like
cougar v demon
iamcaper is offline
post #22 of 76 (permalink) Old 08-11-2017, 11:28 AM
1MTNCAT's Avatar
For yours I pulled the cams from your gallery/garage and looked up the Comp Stage 3 Stats. 102600 - Xtreme Energy? For 1999-up Performance Improvement Heads. Note: Can also be used in Pre 99 (P.I.) Heads with retainer to guide clearance modifications and COMP Cams® 26113 Valve Springs.
Damn Monkey. You running some good size cams in the blower car. I may have to sell mine and move up a step LOL!!!
Steve
1MTNCAT is offline
post #23 of 76 (permalink) Old 08-11-2017, 12:07 PM
post #24 of 76 (permalink) Old 08-14-2017, 09:49 AM
JoeyICU's Avatar
3-5 grand wouldn't buy you the fuel system and tuning to make the power your talking about, I believe a good 20,000 budget may be more like it
if you have 3-5 g's to spend, stick with the simple, gears trans, make the car fun. I had a low 14 bird that had about that in it, and man was that car entertaining.
Hi Steve, nice to see you are still around. Ever come over to this blue state and drag race your car? I need to get wrenching on my bird, I picked up a parts Mark 8 car that is going to further me along a little bit.
JoeyICU is offline
post #25 of 76 (permalink) Old 08-14-2017, 01:27 PM
1MTNCAT's Avatar
Just getting it back together now Joey. Sometime the next couple of weeks it will be going back in. All my old numbers will be falling like rocks after that. Will have to do some testing and tuning once its in. Planning to make a fall run at Cecil if they have the fall event that they have annually.
Planning on attending a few other fall racing venues as well. Interested in seeing how the "Cat" will like having an actual built motor instead of a stocker. Should be fun.
I may bring the Mountain Mule down to tow the Car and send it down a couple passes too!
Woodman and 997Tbird like this.
Steve
1MTNCAT is offline
post #26 of 76 (permalink) Old 08-14-2017, 03:36 PM
Wile E. Coyote Jr.'s Avatar
The engine I built will at most put down 300-310 wheel with a good tune. It has head work, cams, higher compression, and some other stuff. It wont pass Jersey emissions which is easier than Cali. Unless you go forced induction i dont know how youll do it, and to even push 400 wheel you should build the bottom end of the engine. maybe some ported PI heads, HiTech Stage 2 cams, Kooks mid lengths and a true dual system will get to your number, but I would be worried about the emissions side because those cams have a decent idle to them alone.
Stacy: 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Ellie: 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Wile E. Coyote Jr. is offline
post #27 of 76 (permalink) Old 08-14-2017, 04:48 PM
S4gunn's Avatar
Until Ford comes out with a 50-state swap kit with the Coyote engine, the answer is still GM E-ROD.
If you insist on a 400HP CA-emissions legal Ford product, the cheapest solution is likely as follows:
1) Sell tbird
2) Buy 2011 Ford Mustang GT (I'm seeing as cheap as $14K, more typically ~$20K)
https://cargur.us/hZTtX
post #28 of 76 (permalink) Old 08-14-2017, 05:50 PM
1) Sell tbird
Or get a wrecked 2011-14 mustang GT and do a coyote swap using the parts off of it. Itll take a while to say the least but it would be smog legal and make the power.
post #29 of 76 (permalink) Old 08-15-2017, 09:14 AM
JoeyICU's Avatar
ya buddy. I forgot you have a 6.4, I have nightmares about them. They do make power when the engines are not failing. Are you racing over at Cecil more, or somewhere else?
JoeyICU is offline
post #30 of 76 (permalink) Old 08-15-2017, 09:15 AM
JoeyICU's Avatar
how much did this build cost, to put a number on the project for the OP. Not including all the support stuff to go with it.
JoeyICU is offline
