Under load miss at +2500rpm - TCCoA Forums
post #1 of 5 (permalink) Old 10-10-2017, 05:58 AM Thread Starter
coggonobrien's Avatar
So looking for some advice as I've been fighting a miss with my 94 4.6 bird. No check engine light so I've replaced the plugs, wires and coils.
coggonobrien is offline
post #2 of 5 (permalink) Old 10-10-2017, 01:49 PM
T6Rocket's Avatar
Usually those misses related to spark occur at a lower RPM, like 1500, when climbing a hill in OD. High load and low RPM. Hopefully you replaced the coils with Motorcraft?
2500 is above normal cruising RPM, you're really starting to get into the throttle then, unless you have gears.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #3 of 5 (permalink) Old 10-10-2017, 01:51 PM Thread Starter
i run 4.11 gears with a chip
post #4 of 5 (permalink) Old 10-10-2017, 05:00 PM
ikutoisahobo's Avatar
Under load = Coil packs!
ikutoisahobo is offline
post #5 of 5 (permalink) Old 10-11-2017, 05:54 AM Thread Starter
coil packs are new. roughly 105000 miles, original fuel pump
