Running rough - TCCoA Forums
post #1 of 8 (permalink) Old 12-22-2017, 01:18 PM Thread Starter
95chickn's Avatar
Running rough
Just brought 1997 4.6 car only had leaking intake so I didnt know how car truly drove. Well I did the PI intake swap and it runs like crap. Ive visibly check for vacuum leak, replace plugs and wires still running bad. The previous owner said he hollowed out cats but I dont think that would hesitate it. The code i got from scanner is p0171. Side note I cover air filter hole half way and car revs up(little wierd) HELP
95chickn is offline
post #2 of 8 (permalink) Old 12-22-2017, 05:26 PM
Banned
Pop off and check spark plug wires firing order as well as for coolant in the plug wells..try cleaning mafs might have gotten something on the filament during swap..and just double check every sensor is plugged back in..lol this happens every swap I do..or some old vacuum line cracks . those red and green hard lines are notorious for it.
94badbird is offline
post #3 of 8 (permalink) Old 12-22-2017, 07:04 PM Thread Starter
95chickn's Avatar
Yea im going to replace IAC and MAF to see if that helps
95chickn is offline
post #4 of 8 (permalink) Old 12-22-2017, 07:05 PM Thread Starter
95chickn's Avatar
I cant visibly see vacuum leak, could I use smoke?
95chickn is offline
post #5 of 8 (permalink) Old 12-23-2017, 03:01 PM
Banned
Spray carb cleaner along all the vacuum hoses and hard lines and listen for an idle change..mine happen to leak where the plenum met the intake manifold..even with a new o ring gasket it still needed rtv
post #6 of 8 (permalink) Old 12-27-2017, 08:40 AM Thread Starter
95chickn's Avatar
Well after doing a good bit of searching it seems I have a Dorman PI intake. The one with the individual press in rubber gaskets. Could I just install rubber gasket and remove other style gaskets and try again...any modification needed with Dorman
95chickn is offline
post #7 of 8 (permalink) Old 12-27-2017, 09:12 AM
No, you can't use regular gaskets with the dorman manifold. Plus the dorman PI manifold does not give you any performance gain like a real PI intake swap would. If you are going to stick with the dorman manifold, might as well just get the right one for an NPI application.
post #8 of 8 (permalink) Old 12-27-2017, 09:22 AM Thread Starter
95chickn's Avatar
Yea I pull it off a 04 CV at local JYard... im going back to search for the Ford Pi intake
95chickn is offline
