crank but no start - TCCoA Forums
post #1 of 5 (permalink) Old 12-28-2017, 08:17 PM Thread Starter
Unhappy crank but no start
Hey guys so my bird isn't starting for me again ! It will crank over just fine but doesn't even sputter to start leaving me to initially think no spark or no fuel. Well I can hear the fuel pump priming when I turn the ignition to "On" and I know the tank isn't empty cause I just filled it. So I pulled a spark plug to see if it was sparking and it is NOt . With the help of my brother we checked to make sure the coil packs were getting power and they are. I have read a few other threads about a similar issue and even seen a few videos were the guy just unplugs the ICM and then the car fires right up, I tried this with no success. I have also read a bad coolant temp sensor could be an issue, that makes no sense to me but what do I know. The car did have an emissions code when I scanned it P1445 EVP Purge Flow Sensor circuit high input. I just figured it wouldn't make the car not start if anything just hurt fuel economy or have it run rich. When I tried to do a KOEO test on my computer said continuous memory error. I really wanna get my bird rolling again guys at the moment I'm left scratching my head on this one really. Any suggestions welcome thanks ! Also the icing on the cake is that I'm sick right now
1997 Thunderbird Lx 4.6 Liter
etsxp is offline
post #2 of 5 (permalink) Old 12-28-2017, 08:20 PM
Chances are it's an issue with the crankshaft sensor - or the wiring leading to it. A fairly common problem that causes a no-start condition on these cars.
Find it to the left (when facing the engine from the front) of the harmonic balancer next to the A/C compressor. To get it out you'll need to unbolt (let hang - no need to disconnect hoses) the compressor.
post #3 of 5 (permalink) Old 12-28-2017, 08:25 PM
Tbird0718's Avatar
That coolant temp sensor gave me trouble in a 96 Dodge Ram with the same symptoms your describing. I didnít believe it either but when I replaced it that beast fired right up like nothing was wrong. But I donít think these cars are prone to a ect sensor failures so I would honestly listen to the previous advice and start there.
Tbird0718 is offline
post #4 of 5 (permalink) Old 12-29-2017, 10:36 PM Thread Starter
Gotcha
Today I got a new crankshaft sensor and like you said the ac compressor is directly in the way to remove/install the new one. I'm having a difficult time locating the mounting bolts for the ac or even finding any info on what steps you need to do to remove it. I see two bolts on the bottom of it that I removed after an hour or so with the help of a swivel and extensions but there must be another mount up top or something. Do I need to remove the tensioner to get to it? I'm feeling pretty defeated right now on this one any knowledge will help. I took a picture of the bolts I was loosing from the bottom my god that back one sucks to get too! Thanks Terminator !
etsxp is offline
post #5 of 5 (permalink) Old 12-30-2017, 07:05 AM
I think there are three (the 3.8 has 4 but it's on the top of the engine). Two on the bottom (front, rear) and one at the top (front). I usually have decent luck getting at them with a short 10mm socket on a 1/4" ratchet, but if it's never been touched before it might be tough breaking the bolts free with only 1/4" hardware.
