oil filter mount/lower radiator hose inlet - TCCoA Forums
post #1 of 3 (permalink) Old 01-13-2018, 06:27 PM Thread Starter
aka who put that rivet there.
freshly purchased 96 cougar, and that gasket gave out after about 2 weeks, not a problem really except that the lower radiator hose is...unwilling to be removed easily.
So I figured I could get a little more arm space by removing the coolant reservoir and shifting the power distribution box. the coolant reservoir came out easily (one bolt...supposed to be two...) as for the power distribution box...well there were two rivets and a bolt holding it on. Why couldn't they just use bolts, I mean, seriously, why rivets and bolts, why not just rivets?
the rivets didn't last very long...
jhousen is offline
post #2 of 3 (permalink) Old 01-14-2018, 11:58 AM
Banned
With the read hoses I just find something little to wedge into the lip of the hose and slowly work it around until it breaks the bond it makes over time,then wiggles on off.
94badbird is offline
post #3 of 3 (permalink) Old 01-14-2018, 07:15 PM
TwoHaggard's Avatar
Talking about the fuse box under the hood? There’s two nuts (think 10mm) on the other side behind the wheel liner......
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
