Fuel Injector Questions - TCCoA Forums
 3Likes
  • 3 Post By MadMikeyL
post #1 of 7 (permalink) Old 01-22-2018, 12:54 PM Thread Starter
Banned
Planning a slight build.
Current ride is 98lsc with exhaust ,upgraded intake cams and superchips tuner..
I plan nitrous,255lph fuel pump and 90mm lmafs.
Here's my ?. Can I install the 42s now,before tune and lmafs with no major issues..Ive used 24s on non tuned sohc no issues..
They won't be used but 1000 miles n 2 months TOPS until I get the other parts and tune..reason I don't wanna wait is i could sell or trade my stock 24s in the meantime..if all it does it make it run richer ,fine for now ..I have exhaust ,cam and my tune advanced the timing and she almost seem lean rite now as I get a little pinging I cam hear the 1st few seconds I shut it off.
94badbird is offline
post #2 of 7 (permalink) Old 01-22-2018, 02:03 PM
No, if it runs at all, it will wash down the cylinder walls and wear out the rings and cylinder bores.
post #3 of 7 (permalink) Old 01-22-2018, 02:25 PM
I know you're going to do it anyway, but Mikey is exactly right. Additionally you'll also likely wipe out the o2 sensors and kill the cats if you still have them.
And before you ask, no, the lmaf won't magically match the injectors either.
post #4 of 7 (permalink) Old 01-22-2018, 07:16 PM Thread Starter
Banned
I'm aware about the mafs matching b.s....I was scared about wash too..
I coulda maybe got by with just 30s over the 24s but yaaaa lol 42 is different..
Damn...
post #5 of 7 (permalink) Old 01-22-2018, 08:32 PM
I have a MarkVII in the shop right now where someone thought 30's would be ok without a tune. It wiped out the cylinder walls to the point that the block was useless, and in addition to new pistons and rings, I had to get another block, have it machined, and then transfer everything over. The guy's bill is going to be around $4K just to fix what he broke by driving it untuned for a few thousand miles. If you change injectors, you need a tune, plain and simple.
post #6 of 7 (permalink) Old 01-22-2018, 09:22 PM Thread Starter
Banned
Omg...and this is why I ask you gurus
post #7 of 7 (permalink) Old 02-21-2018, 12:42 PM
iamcaper's Avatar
just calibrate it : https://www.ebay.com/itm/Delta-Force...RRYpN9&vxp=mtr
works for me
drive fast!
iamcaper is offline
