Gauge port location on back of head? - TCCoA Forums
post #1 of 3 (permalink) Old 06-15-2018, 10:44 AM Thread Starter
Thunderstruck95's Avatar
Does anyone know if there is a plug on the back of a 2 valve 4.6 cylinder head that could be used as a port location for a temp gauge?
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #2 of 3 (permalink) Old 06-15-2018, 10:57 AM
Not unless you count the freeze plugs, the screw on plugs on the heads are all for oil gallerys/feeds. My DOHC coolant crossover had only one temp sensor bung, so I ended up using the gauge temp sensor in one of the block drain holes on the driver side, which works reasonably well.
post #3 of 3 (permalink) Old 06-15-2018, 02:36 PM
If you get a rear tube from an satc car, it fits in the back of the head and goes to the heater core; it has a sensor bung in it.
