Time for a head swap! - TCCoA Forums
 2Likes
  • 1 Post By Paulyrats
  • 1 Post By Trunk Monkey
post #1 of 7 (permalink) Old 10-29-2018, 09:31 PM Thread Starter
Paulyrats's Avatar
So turns out my valve seals are shot on my svo bird.. so I was looking into the trickflow 44cc heads and a set of comp XE268H cams. Would this be a good combo? My full build specs are in my signature. Thanks!
Woodman likes this.
-PAULYRATS-95-4.6L-THUNDERBIRD-LX
SVO SUPERCHARGER @ 9PSI
70MM TB,76MM MAF
30# INJECTORS, 255 LPH FUEL PUMP
SNOW PERFORMANCE METHANOL INJECTION
SCREAMIN DEMON COILS, LIVEWIRES PLUG WIRES
CUSTOM LONGTUBE HEADERS,2.5" DUAL EXHAUST
JMODDED 4R70W, 9.5” 3200 STALL TC
93 MARK VIII DS, 3:73 REAR GEARS
TUBULAR REAR UPPER CONTROL ARMS
IRS REAR TORSIONAL LOAD BRACE
REAR STRUT TOWER BRACE, SCP PINION BRACE
HEAVY DUTY POLY REAR DIFF MOUNT
1.5” DROP EIBACH SPRINGS
18x9 SALEEN REPLICA WHEELS
COBRA R STYLE HOOD
Paulyrats is offline
post #2 of 7 (permalink) Old 10-30-2018, 12:52 PM
Oh hell yea! That's the same setup that I ran 11.5 at ~117 mph with on E85.
You'll want to switch to the 42 lb injectors and have the car tuned. Also to go E85 you'll need a higher capacity fuel pressure regulator.
RobertP can talk you through it.
post #3 of 7 (permalink) Old 10-30-2018, 02:59 PM
Didn't you have to go to E85 due to pump gas not cutting it?
This would be a nice compression bump, and those cams would rock.
The book I have of various builds mentions wishing TF made a 4.6l head; it was from 2006.
post #4 of 7 (permalink) Old 10-30-2018, 04:38 PM
93 pump gas will work fine with a stock bottom end and 44cc TF heads. The compression ratio is around 9.5:1
My problem was with my new engine having a 11.5:1 CR.
It doesn't like 93 Pump gas.
Grog6 likes this.
post #5 of 7 (permalink) Old 10-30-2018, 05:49 PM Thread Starter
Paulyrats's Avatar
Awesome! I was hoping I’d be able to stick with the 93 octane, I don’t mind stepping up injectors, but I just replace all fuel system components and didn’t want to do it again. Also trunk monkey do you remember the hp & tq your car made on the old set up?
70MM TB,76MM MAF
COBRA R STYLE HOOD
post #6 of 7 (permalink) Old 10-30-2018, 07:09 PM
1st Pull: 382.92 rwhp / 388.71 rwtq
2nd Pull: 375.94 rwhp / 392.02 rwtq
Run Conditions: Temp. 74.77° F, 29.73 in-Hg, Humidity 10%, SAE 1.01
All the details are in my garage. I sent you a link in the PM that I replied to.
post #7 of 7 (permalink) Old 10-30-2018, 07:13 PM Thread Starter
Paulyrats's Avatar
Nice! Thanks for the info! I’ll check out the link
70MM TB,76MM MAF
COBRA R STYLE HOOD
