'95 Tbird heater core inlet vs. outlet - TCCoA Forums
 1Likes
  • 1 Post By MadMikeyL
post #1 of 8 (permalink) Old 11-04-2018, 04:01 PM Thread Starter
Have done the 4v cooling mod using MMR's product that connects both cylinder heads (driver side cylinder freeze plug must be removed).
I have searched the forum to find out which heater core side is inlet and which is return. The mod of course goes to the supply side of the heater.
I did find one post that said left side is return. But it seemed ambiguous as I couldn't figure out if it was his left as he was looking at the front of the engine bay or left from the car's perspective.
My question is- if I am sitting in the car, facing forward, ('95 Thunderbird 4.6L) is the outboard most heater core tube inlet or return?
Thanks for your help as without it, I would not have even attempted to do this engine swap. Almost there-- engine goes in next week.
'95 LX 4.6L/ '99 mustang front calipers/ '96 t-bird rear calipers/Baumann transmission/BOC chip by Lonnie/ 225.55.16 Yokohama's on Borbet 5 spoke/poly IRS/ Eibach 1.5" drop/ Lincoln pumpkin with 3.55 trac-loc/ Lincoln rear upper and lower control arms/ rebuilding '94 Mark Vlll eng. for swap/ -Edit- Engine rebuild now finished by Panhandle Performance (2-16-07)/ swap on soon - but needing to get P.I. torque converter- MSD window switch for '98 IMRC'S- rebuild current Baumann Trans--etc.
Thundernerd is offline
post #2 of 8 (permalink) Old 11-04-2018, 04:48 PM
FWIW, it doesn’t matter, I flipped my hoses around with my Aviator motor swap for better access.
Stock driver side = inlet from manifold(or head for 4Vs)
Stock passenger side = outlet to valley bypass
post #3 of 8 (permalink) Old 11-04-2018, 04:59 PM Thread Starter
Thank you Matt for the quick reply.
Also good to know that it doesn't matter- that's a damn good tip to know.
I really appreciate it.
post #4 of 8 (permalink) Old 11-14-2018, 02:15 PM
crzy4nos's Avatar
sorry I haven't been on in a while but I scitch mine back and forth every year to keep it from plugging .
crzy4nos is offline
post #5 of 8 (permalink) Old 12-03-2018, 08:53 AM
Wickedshifts's Avatar
This may help my issue as well. Got a 96 4.6 and with a new radiator & hoses, water pump, thermostat, heater core and heater core hoses. I get practically zero heat while the car is in motion and it takes forever for it to warm up & defrost the windows. And even traveling at 70mph on the interstate for 45mins+ it never reaches 'Normal' operating temp. Always reading cold unless it's sitting still.
It blows cool air, even with the heat set to high (Manual temp. control) at least this post would give me a reference to see if I crossed the heater core hoses.
-- 1996 Ford Thunderbird 4.6 SOHC V8. 118k miles on body, 100k miles on engine. Bone stock... for now... --
Wickedshifts is offline
post #6 of 8 (permalink) Old 12-03-2018, 09:25 AM
If the temperature gauge is never coming up to temp, then the heater core is not your problem. I would start with replacing the thermostat, since it may be stuck open, or missing entirely if it has done this since you first got the car.
Wickedshifts likes this.
post #7 of 8 (permalink) Old 12-03-2018, 09:45 AM
I bought the car for $400 with a cracked block. So I put in a new engine and replaced all the cooling components and it has done it since I got the car running back in May. I don't drive it much, still needs some front end works (balls joints are squealing a little) and shocks.
I'll pick up another thermostat on my way home after work today and see if I can narrow it down. At least it's a cheap & easy swap. Haven't thought much about it since its sitting in the garage. Seeing this post reminded me of it lol
post #8 of 8 (permalink) Old 12-03-2018, 11:19 AM
Just double check to make sure the thermostat is facing the right way.
