spark plug torque? - TCCoA Forums
post #1 of 5 (permalink) Old 02-10-2019, 11:21 AM Thread Starter
jtavares0701's Avatar
spark plug torque?
In the garage as we speek and cant find torque specs for the plugs on my 96 tbird 4.6...does anyone know?
jtavares0701 is offline
post #2 of 5 (permalink) Old 02-10-2019, 01:29 PM
Urambo Tauro's Avatar
"9-20 Nm (80-177 lb-in)." Approx 7-14 lb-ft
Urambo Tauro is offline
post #3 of 5 (permalink) Old 02-10-2019, 01:31 PM
CDsDontBurn's Avatar
Searching this answer would have resulted in the answer, 13lbs.
Or you can hand torque them until "snug" is also appropriate.
CDsDontBurn is offline
post #4 of 5 (permalink) Old 02-10-2019, 07:15 PM
Woodman's Avatar
The stock NPI heads are more forgiving than later PI Heads. PI heads have 4 threads (can't recall if later year models revised this or not). If you over torque spark plugs in a PI head, they'll blow out.
Woodman is offline
post #5 of 5 (permalink) Old 02-10-2019, 08:30 PM Thread Starter
I did search but found different answers. ended up going with 12 ft lbs. Didnt think i was going to need wires but i think i do now. After new plugs she idles with a slight skip. Double checked the wires and they are correct to the firing order. Tomorrow ill be doing wires. got caught up doing my water pump also today
Similar Threads
Spark Plug and Spark Plug Boot Problem missycougar Engine - 4.6L & 5.4L 2 03-16-2008 06:52 PM
Spark Plug wires and plug recommendations thunter Engine - 4.6L & 5.4L 4 07-27-2006 02:54 PM
Spark Plug Gap? Cougr17 Engine - 4.6L & 5.4L 1 08-09-2002 05:01 PM
spark plug wire install...anything to watch ouit for? jrb23 Engine - 4.6L & 5.4L 4 08-08-2002 12:37 PM
9mm spark plug wires needed/OD? Roman Engine - 3.8L & 4.2L 2 07-26-2002 12:51 PM
