PI Upgrade for 4.6 1997 thunderbird - TCCoA Forums
 2Likes
  • 2 Post By XR7-4.6
post #1 of 8 (permalink) Old 02-25-2019, 10:23 AM Thread Starter
So I believe I’m ready to take my car to a shop to begin work. I have the Pi intake, a Romero set of Pi heads and cams, and gaskets plus a spacer in case the alternator needs to be moved. But I’m looking for a detailed list of everything that needs to be done so the mechanic knows exactly what I want him to do. Any help you can offer in either finding one or creating one is highly appreciated.
1997 Tbird is offline
post #2 of 8 (permalink) Old 02-25-2019, 11:51 AM
Woodman's Avatar
Originally Posted by 1997 Tbird View Post
So I believe Iím ready to take my car to a shop to begin work. I have the Pi intake, a Romero set of Pi heads and cams, and gaskets plus a spacer in case the alternator needs to be moved. But Iím looking for a detailed list of everything that needs to be done so the mechanic knows exactly what I want him to do. Any help you can offer in either finding one or creating one is highly appreciated.
I see you are new, with all of four posts, but please, please be sure to read the stickies in here. They have LOTS of the important info all ready to go for you. For example, one of the stickies in this particular area is right here... Merely four posts above yours.
https://forums.tccoa.com/7-engine-4-...76-1997-a.html
You don't need a spacer on the alternator. You need the intake, the heads, the cam covers, and a tune. If you don't have a tune, it won't run well.
Woodman is offline
post #3 of 8 (permalink) Old 02-25-2019, 11:55 AM
You don’t need new valve covers if the heads are Romeo, just reuse the stock ones(get new gaskets/grommets though)
Woodman and CDsDontBurn like this.
post #4 of 8 (permalink) Old 02-28-2019, 09:11 PM
decipha's Avatar
If you aren't doing the work yourself I would highly advise against doing a PI swap unless your upper end needs to come off regardless.
If your going to pay to get the work done your much better off with trickflow heads otherwise the PI heads are not worth it IMO.
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #5 of 8 (permalink) Old 03-01-2019, 03:18 PM
jtavares0701's Avatar
For future reference when I go for this upgrade myself. To be honest tunes are completely foriegn to me. Where would I go and how much should I expect to pay for a tune?
jtavares0701 is offline
post #6 of 8 (permalink) Old 03-01-2019, 03:58 PM
Where do you live?
I'd guess the going rate is around $500. You'll also need to buy a SCT X-Cal, or whatever the latest name for the tuner is, to keep your tune on.
https://www.sctflash.com/products/tuners
Air silencer delete, warp drive, dilithium crystals, flux capacitor, Slingshot Rubber band power adder, Moonshine & Gas, Leaf Blower Supercharger, Hamster Wheel & Hamster, Energizer Bunny generating 1.21 gigawatts, Mr. Fusionģ Home Energy Reactor, hover conversion and a sextant celestial navigation system (The original GPS)
post #7 of 8 (permalink) Old 03-01-2019, 08:04 PM
Woodman's Avatar
Where do you live?
Buy a used, unlocked one on ebay for ~$150 or so.
A N/A tune from Don Lasota is $100.
Woodman is offline
post #8 of 8 (permalink) Old 03-01-2019, 11:19 PM
I live in Massachusetts. Wow thats a lot cheaper then i expected. Is this sct tuner something you plug into the obd2 port and set up yourself?
Similar Threads
Upgrade 1997 Sound System Tbird Bob Audio / Electronics 16 12-12-2017 09:32 PM
It's been a while...PI cam upgrade question Embalmer Engine - 4.6L & 5.4L 4 04-02-2014 10:31 PM
Ported Non-pi w/ Pi cams vs. Ported Pi Heads??? Quickerthanu Engine - 4.6L & 5.4L 31 11-24-2002 08:11 PM
port and polish for stock intake and heads and pi cams good upgrade? unionn Engine - 4.6L & 5.4L 11 11-18-2002 01:37 PM
