Help, Mark VIII Fuel Injector Wiring Diagram - TCCoA Forums
post #1 of 3 (permalink) Old 03-06-2019, 04:36 AM Thread Starter
wildturkey's Avatar
Foolishly, I did not label my wiring loom before I cut and stripped the tape. My confusion is with the injector side of the harness and need the color of the wire to the injector/cylinder. I'm using a 93-95 Mark VIII harness. Your help would be appreciated.
Read ya later, Nick
wildturkey is offline
post #2 of 3 (permalink) Old 03-06-2019, 11:07 AM
I can't easily attach the diagram itself, but here is the wiring breakdown for a 95 MarkVIII.
Red is common power to all injectors and various sensors, supplied by the ECM. Ground controlled by the ECM on the following wires
#1 Tan, pin 58 on ECM
#2 White, pin 59 on ECM
#3 Brown/Yellow, pin 39 on ECM
#4 Brown/Light blue, pin 35 on ECM
#5 Tan/Black, pin 15 on ECM
#6 Light green/Orange, pin 12 on ECM
#7 Tan/Red, pin 13 on ECM
#8 Light blue, pin 14 on ECM
MadMikeyL is online now
post #3 of 3 (permalink) Old 03-06-2019, 10:56 PM Thread Starter
wildturkey's Avatar
Thank you, sir. That's the info that I was looking for.
Read ya later, Nick
Similar Threads
Mark Viii Looking For Starter Wiring Diagram to fix NO CRANK 93mark8rules Engine - 4.6L & 5.4L 11 10-04-2015 09:41 PM
93 mark VIII Transmission wiring diagram needed Slowpoke 4R70W Transmissions 1 11-10-2009 06:35 PM
Ineed a 1993 lincon mark 8 charging wiring diagram blown96bird General Tech 0 10-22-2008 12:49 AM
Fuel injector wiring? T-BIRDS281E Engine - 4.6L & 5.4L 7 03-04-2008 01:59 AM
