a sputter after filling up - TCCoA Forums
 3Likes
  • 2 Post By Trunk Monkey
  • 1 Post By Djose13
post #1 of 7 (permalink) Old 03-06-2019, 01:36 PM Thread Starter
ok I checked the fuel pressure and swapped out the plugs and checked the fuel pressure regulator. also changed out the fuel filter as well as checked the spark out of my coil packs. it is a 95 4.6 with the rebuilt bottom to match the pi heads and stock pi cams. I rebuilt it because it had pushing over 300k on the original motor. the motor is strong granted it still has a rebuilt trans in it from 150k just wondering what I missed I checked all of the vacume lines as well as fuel air and spark. I am wondering if the fuel pump is just saying it is done even though it gave decent pressure
95mercxr7 is offline
post #2 of 7 (permalink) Old 03-06-2019, 03:41 PM
It could be the gas. Pull a sample and look at it. Also, try dropping a can of Seafoam in the tank.
That's all I got. It sounds like you've covered everything else.
T6Rocket and Djose13 like this.
post #3 of 7 (permalink) Old 03-08-2019, 10:33 AM
It was running fine before you filled up, and is now running like crap afterwards? Trying to clarify the issue a little is all.
T6Rocket likes this.
Djose13 is offline
post #4 of 7 (permalink) Old 03-08-2019, 01:53 PM
If your tank was about empty and then filled it up it might have gotten trash around the fuel filter .
Have seen this issue before.
post #5 of 7 (permalink) Old 03-14-2019, 07:49 PM
Might also be a bad tank of gas (or rather, not the stated octane)
This sounds like the conditions where I get a bottle of octane boost...
jhousen is offline
post #6 of 7 (permalink) Old 03-16-2019, 07:26 PM Thread Starter
89 octane I always put it in after rebuild of pi things
post #7 of 7 (permalink) Old 03-16-2019, 08:25 PM
Well, it's been 10 days. Have you figured it out or run that tank out and refilled with fresh gas yet?
Similar Threads
Stupid question: Fluid filling after draining torque converter? TBird94 4R70W Transmissions 8 11-25-2014 03:50 PM
Cooling; draining, filling, bleeding????? conradcliff Engine - 4.6L & 5.4L 8 02-23-2005 03:34 PM
Okay I'm sold on the SCT. Need Help filling out the ordersheet teenageriot13 EEC Tuning 4 01-02-2005 10:21 PM
Tranny not filling chrisnack Drive Train 4 07-18-2004 08:29 PM
Fuel filling problems 94t-birdlx General Tech 6 01-13-2004 03:04 PM
