A/C compressor clutch - TCCoA Forums
post #1 of 5 (permalink) Old 04-08-2019, 09:04 PM Thread Starter
30thAnniversaryCat's Avatar
My a/c is blowing only warm air. The compressor clutch is not engaging, but the low side pressure gauge says the pressure is normal with the a/c set on max a/c and fan on high. I know that the pressure sensor switch will not let the clutch engage if the pressure is too low, but Iím afraid to add r134 with the gauge showing the system is adequately filled. Any advice is welcome.
30thAnniversaryCat is offline
post #2 of 5 (permalink) Old 04-08-2019, 09:32 PM
Disconnect the connector from the low side cycling switch on the accumulator and jump it closed momentarily. Does the clutch engage?
97 Laser Red Thunderbird LX 159k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
98 Black Mark VIII 150k, stock daily driver
07 Redfire Fusion V6 SEL 176k, for the wife
post #3 of 5 (permalink) Old 04-09-2019, 08:43 AM Thread Starter
Do I jump across the connector or the accumulator side?
post #4 of 5 (permalink) Old 04-09-2019, 08:05 PM
Jump the connector (with AC on, obviously).
If it works, there may be a problem with the cycling switch. If you remove the switch (don't worry, there's a valve under it so you shouldn't lose refrigerant when removing it) and hook it up to compressed air, it should close when more than ~40-45 PSI is applied. If you don't hear it click and there's no continuity between the two contacts under pressure, the switch is faulty and needs to be replaced.
post #5 of 5 (permalink) Old 04-15-2019, 11:35 PM Thread Starter
Took it to mechanic, who put the gauges on both sides. It was so low on refrigerant, that the low side cycling switch was disabling the clutch. He put vacuum on it, recharged, and, voila, weíre back in business. Clearly, thereís a leak, but thatís for later.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
danmanmeatman
Similar Threads
A/C Compressor Clutch?? Pearl97LXSPORT Exterior 5 09-17-2008 05:30 PM
Symptoms of Compressor Going Bad? Bradley Blaze General Tech 0 08-12-2002 06:07 PM
March pulles..no compressor =no install MZ-Bird Engine - 4.6L & 5.4L 2 08-08-2002 10:07 AM
A/C Compressor Question... IronChopz General Tech 3 08-02-2002 11:32 PM
