Head Gasket 4.6 blown - TCCoA Forums
 6Likes
  • 2 Post By theterminator93
  • 2 Post By Grog6
  • 1 Post By XR7-4.6
  • 1 Post By theterminator93
Old 06-24-2019, 09:52 AM Thread Starter
Can anyone tell me how hard is it to remove the heads from a 97 tbird
Can you remove the heads with the exhaust manifold or do they have to
come off the heads before removing the heads.
Thanks.
thatglockguy is offline
Old 06-24-2019, 10:13 AM
Removing the heads isn't terribly difficult, just a lot of removing stuff in the way. Harness, fuel rail, intake manifold etc. Worst part is probably trying to get the valve covers off - some of those little 8mm bolts at the back can be a squeeze. Rubber band the middle head bolts to each other to help hold them up in the head when you lift them out so they clear the block - their length and angle/position is such that they can't be removed/installed due to interference from the shock tower (if you don't know what I mean, you will ). You can get the heads off with the exhaust manifolds attached.
Blown head gaskets on a 4.6 are not unheard of but are relatively rare, FYI. [How] Are you certain the HGs are blown?
RalphP and CDsDontBurn like this.
Old 06-24-2019, 11:16 AM
I'm with theterminator93; unless you drove the car without water for a good distance, the odds are you need a new gasket on the oil filter adapter.
The only case I'm aware of blown headgaskets was someone who overheated the car and drove it thru a construction zone until it seized.
That warped the heads; so if you just have milkshake in the cooler overflow, I'd go with a new gasket on the oil filter adapter first.
Old 06-24-2019, 11:30 AM
The dipstick tube is by far the worst part of doing the heads in car. Get yourself a 8mm swivel socket for the tight valve cover bolts
I seriously doubt the head gaskets are bad either.
RalphP likes this.
Old 06-24-2019, 11:53 AM
Ah yes, Matt revived those repressed memories of the yucky experience of getting the dipstick tube out of the block. If you leave the exhaust manifolds attached when installing or removing them, it has to come out. After the hacksaw, vise-grips and channel-locks, one mangled former disptick tube came out for me - so I put a Lokar in when I reassembled.
+1 worst part of the job!
RalphP likes this.
Old 06-24-2019, 12:06 PM
I personally think removing the engine as a whole is easier than doing it in the car; I can have an engine out in an hour or so.
Bending over the engine while even pulling the valve cover gaskets makes my back hurt just thinking about it, lol.
Old 06-24-2019, 12:16 PM
I was a glutton for punishment so I reinstalled the stock dipstick tube in lieu of the lokar Installation was even worse than removal, I must have tried every contortion possible to get the tube where it needed to go without binding up in the manifold and head. Once I finally did get it near where it needed to go I had to use vice grips and a slide hammer to get it seated(reverse process I had to use for removal), while the loose head was basically just resting precariously on top, it’s lucky I didn’t damage the new head gasket or gouge the deck surface in the process.
Similar Threads
How common is the 4.6 to blown head gasket?+my problem and rant Monk Engine - 4.6L & 5.4L 32 04-21-2003 10:24 PM
Blown Head Gasket? MaddMartigan Engine - 5.0L & 5.8L 2 03-20-2003 08:42 PM
Blown Head Gasket ... can i avoid it? TBird 38 LX Engine - 3.8L & 4.2L 60 02-15-2003 11:07 PM
Blown head gasket? >200000 Engine - 3.8L & 4.2L 7 01-25-2003 08:05 PM
blown head gasket 96TBird Engine - 4.6L & 5.4L 1 07-20-2002 12:33 AM
