Best Brand Aftermarket Intake Manifold - Page 2 - TCCoA Forums
 19Likes
post #31 of 71 (permalink) Old 08-12-2019, 10:17 AM
FYI the nipple is plastic on the Ford PI intakes too
post #32 of 71 (permalink) Old 08-12-2019, 10:27 AM Thread Starter
That's better so you won't have different expansion rates.
Bluebird
97Bluebird is offline
post #33 of 71 (permalink) Old 08-12-2019, 02:29 PM
Well, back in 2017, the wife's car (1997 Cougar) finally blew an intake manifold gasket ....looking at everything, I decided to just replace the intake with a Dorman unit. Now I am typically not the biggest fan of Dorman...parts are typically good, but not great...this is an exception. From my research, Dorman changed their manufacturing specs/design about a year or so prior ...I ordered and received the new intake....it was actually (IMHO) a better design than the OE intake (which yes was replaced with the oe updated design in about 1998).
As an FYI, the Dorman intake does not utilize any of the oe cylinder head to intake gaskets...as they have incorporated these as individual units into the intake itself (eliminating one layer of gaskets).....IMHO, this was good from several points one of which when installing the intake, there is much less chance of damaging the gasket (although slim, it you got a little rough with it by accident, it could cause an issue) and makes it a much less of a headache aligning things up. But the biggie I saw was the runner design.....although definitely paralleling the oe unit, it did not have near as many of the horizontal type flow restrictors as the oe unit......a little casting flash (vertically) was there but nothing my dremel tool with sandpaper couldn't clean up in 20 minutes. The port alignment was excellent (which with their previous model, it was posted that sometimes you had to cut excess material off the outside of the flange to get it to fit).
Final result.....perfect seal & fit on the 1st time out....car runs excellent as good as it did before (no torque loss as others have reported with the previous model) and the upper rpm (4K+), seems to run a little better actually......IMHO...(ie. less obstructive flow pattern in the runners)
The new gen dorman manifold that they came out with about 2 years ago is really a good unit....I waited until I was convinced before replacing the intake on my wifes 97 cougar sport (4.6)…...the one issue that they most all have is the TB mounting location...vacume leak very common....use a touch of senor safe silicone and that resolves it (had 2 intakes on different vehicles with that issue). The intake runners are nicely formed with little to no casting flash to be removed (unlike their earlier ones)…...IMHO...I also used a touch of Permatex non-hardening gasket glue around the water jackets just for my comfort
I have a good one laying around my house right now......send me an email if you are interested.
beechkid is offline
post #34 of 71 (permalink) Old 08-12-2019, 03:39 PM
Those clever integrated gaskets have their downside
This intake was two years old when I took that pic!
post #35 of 71 (permalink) Old 08-12-2019, 05:04 PM
That's one of the reasons that I use a touch of Permatex at the water ports.....and I have also always used an anode in the cooling system which indirectly helps with a variety of issues...….and I also get a lot of questions such as, "The oem radiator lasted 17 years?...it was the plastic that started cracking?"
beechkid is offline
post #36 of 71 (permalink) Old 08-12-2019, 08:05 PM Thread Starter
I ended up cancelling my order on the aftermarket intake and going to the junkyard and getting two PI manifolds. They ran a $46 each. I ordered all the parts I need to do the conversion. Should be good. I have another 97 with a Dorman manifold and may change that one later if needed.
Bluebird
post #37 of 71 (permalink) Old 08-12-2019, 09:36 PM Thread Starter
You musta run that engine way hot to do that.
Bluebird
post #38 of 71 (permalink) Old 08-13-2019, 09:34 AM
No. That happens to all of them in time.
post #39 of 71 (permalink) Old 08-13-2019, 09:53 AM Thread Starter
Not true. I have been running a Dorman manifold for the last 12 years and over 100K miles. Never got hot or melted anything. You did something wrong.
Bluebird
post #40 of 71 (permalink) Old 08-13-2019, 10:08 AM
I'd say Mikey has swapped a few of those; he runs a shop, and those fit a lot of cars.
Grog6 is online now
post #41 of 71 (permalink) Old 08-13-2019, 10:33 AM
That’s not the only one I’ve seen that happen to. The compression of the tightened gasket appears to put pressure on the inside wall of the plastic lip and after enough heat cycles it begins to bulge out and crack from the outside in the passage. It happens underneath the crossover too(to be fair, Ford intakes can have this happen here, though it’s not as common due to thicker wall thickness and better material)
The notion that this is user error is pretty humorous, you must work in Apple support The only reason I posted that pic of mine was to show there’s a downside to:
Less chance of damaging, eh? I have never, ever, had a issue with separate OEM gaskets, the OEM design itself is pretty foolproof, as they clip into the heads. The additional convenience of Dorman’s integral gaskets is outweighed by the failure point they introduce. The issue of installing it wrong somehow to cause the failure on the Dorman(overtightening? Tightening out of sequence perhaps?) still wouldn’t lead to this to happen with OEM. I’ve even pulled OEM intakes from junkyard engines that had signs of overheating where there was no apparent damage to the manifold.
post #42 of 71 (permalink) Old 08-13-2019, 10:59 AM Thread Starter
I bought a couple of PI intakes from the junkyard yesterday. They are hard to find. One was off a 2007 Town car and the other a 2007 Crown Vic. I have to wonder though if they are original. No where does it say "FoMoCo"
or have the Ford oval on either one. They do both say Made In USA and have a "W" logo on the upper surface. They also specify the P/N for the gaskets to use imprinted right into the upper runners. Do these sound original or? Is there a difference between these junkyard manifolds and the FPP one? Even on the junkyard ones, it says Made in China on the aluminum crossover piece.
Bluebird
post #43 of 71 (permalink) Old 08-13-2019, 11:19 AM
Made in China doesn’t sound right, there should be a Ford part number cast on the bottom of the aluminum crossover between ports. The other tell with Ford intakes VS dorman is there are no holes into the valley between the 2-3 and 6-7 runners, just solid plastic.
The FRPP is identical to the production part though.
post #44 of 71 (permalink) Old 08-13-2019, 11:38 AM Thread Starter
I looked at several newer Crown Vics at the junkyard. They all had this same manifold and there are holes in between 2-3 and 6-7. The plastic part is Made in the USA but the aluminum part is Made in China. The number on the bottom of the manifold is 615-175 and the number on bottom of the crossover is RN003-05. It appears that Ford is using these manifolds as original equipment on these newer cars. One was a 2007 Lincoln Town car and the other a 2007 Crown Vicky. I bought both manifolds and they are identical as I described with all the same numbers.
Bluebird
post #45 of 71 (permalink) Old 08-13-2019, 11:49 AM
It’s possible they came from the same livery/taxi service and they put those intakes preventatively. Did they still have their plastic engine covers?
post #46 of 71 (permalink) Old 08-13-2019, 11:55 AM Thread Starter
I have come to the conclusion that they are both PI Dorman manifolds. Don't know what plastic engine covers are. Those two cars were definitely not from the same owner or fleet. It's strange that both had been replaced. Doesn't say much for the original Ford piece if two random 2007 cars had been changed to Dormans. These manifolds look fine, so I guess I will run them.
I'll have to get the Dorman gaskets though because the Ford ones won't work.
Bluebird
post #47 of 71 (permalink) Old 08-13-2019, 12:49 PM
It’s not unusual for a company running those cars for taxi/livery would replace the intakes even if they haven’t failed, just based on their experiences with the OG all plastic ones they would have been operating in the past, it’s better to replace them preventatively than lose fares and an engine on duty. It doesn’t say much about the Dormans either, those may not even be the first ones they installed.
post #48 of 71 (permalink) Old 08-13-2019, 01:24 PM Thread Starter
Why would they replace the Ford ones on a 2007? The plastic crossover manifolds were long gone back in 2001. And these cars were from different junkyards and not fleet cars.
Bluebird
post #49 of 71 (permalink) Old 08-13-2019, 01:47 PM
Already explained why. How do you know they weren’t fleet cars? The manifold failure isn’t a secret to any company operating these cars for their business, and wouldn’t be out of the ordinary for them to do the same procedures - replace the Ford manifold regardless of whether or not it they’ve gone bad. No surprises. Why did you buy two manifolds from two junkyards?
I can tell you with absolute 100% certainty that Ford never used Dorman intake manifolds on the assembly line.
post #50 of 71 (permalink) Old 08-13-2019, 04:03 PM Thread Starter
If he runs a shop, he does this work for the general public. How do you know the customer didn't run it hot. He would have no idea of the history. I have never had a manifold do this. But then again, I have never gotten one this hot. This is obviously heat damage, not just over tightening the bolts. And besides, these manifolds have steel sleeves in the bolt holes to keep excessive stress off the manifold.
Bluebird
post #51 of 71 (permalink) Old 08-13-2019, 04:52 PM
Let me guess, you're a rep for Dorman, right?
Post a pic of the two manifolds you got from your JY trip; most of us don't believe you.
And put something in the pic, so we know they are your photos.
We know Dorman intakes are trash; you don't believe it.
I think there a lot of disbelief "on both sides", lol.
Grog6 is online now
post #52 of 71 (permalink) Old 08-13-2019, 04:56 PM Thread Starter
I bought two because I have two 97 T Birds. I know the Dormans didn't come with the cars on the assembly line. The two cars were different colors and different makes. Not the same fleet.
Bluebird
post #53 of 71 (permalink) Old 08-13-2019, 05:16 PM
The same question can be posed for the OEM failures. The gaskets squash when tightened in order to seal, it’s not a matter of overtightening, when the seal is squeezed onto the manifold, force from the gasket is applied in every direction, the one 1/8” from the port naturally is the one that gives way. Heat is a factor, of course, but there’s nothing to prove it’s from normal 200° heat or 230° overheating. After enough cycles it just tends to weaken. Do the Ford intakes that fail only fail when overheated? I didn’t think so. And Ford’s composite is a damn sight better to the brittle Dorman plastic.
I asked how do you know they weren’t both fleet cars, not whether or not they were part of the same fleet, you answered that several posts ago and I responded to it. If they were both in operation from two different companies, it’s just as probable they’d each have new intake manifolds for the same reasons I already outlined in my two previous posts.
post #54 of 71 (permalink) Old 08-13-2019, 06:00 PM Thread Starter
I have never been able to post pictures to forums. I don't have a smart phone, just a 35mm and when I try, they always tell me I have too many pixels to transmit. Anyway believe me or not, I ended up with two Dorman manifolds from random 2007 cars.
Bluebird
post #55 of 71 (permalink) Old 08-13-2019, 06:12 PM Thread Starter
The Dorman plastic on the manifolds I bought yesterday are also made in the USA. It's molded right into the runner. Have you had a lab analyze the two materials? Otherwise you are just guessing. I know we like to think of original Ford parts as being better. It's possible that this Ford one is made outside the US. Someone would have to send both manifolds to a materials laboratory to know for sure. No, I am not a Dorman employee but these PI Dormans do look mighty fine. If these manifolds are both off of fleet cars, maybe they know something we don't to go to all the trouble of changing them so early. It doesn't make sense that they would change them just for preventing a future problem since the plastic ones were long gone by 2001.
Bluebird
post #56 of 71 (permalink) Old 08-13-2019, 06:44 PM
Woodman's Avatar
Originally Posted by r429460 View Post
I have run the non-PI intake, PI intake, Typhoon and the street heat trick flow intakes on my cougar.
All of them work in the proper rpm range.
Get the intake manifold for the rpm range you intend to run.
Totally stock engine NPI or PI for a little more get up and go.
The Typhoon was slightly better than the PI.
Advantage of the Typhoon is all aluminum, fully portable and will never crack of break from too much boost.
Typhoon cost is not worth the performance gain unless you are supercharger or turbocharged.
TFS Street heat is a 7000 rpm manifold, not worth the cost unless you are running those rpm with heads, cams, valve springs and headers to match.
Fortunately, at the present time my junk works with this one.
Questions about the Typhoon intakes.
I like to replace parts once. I'm overall happy with the PI manifold, but the Typhoon appears to be a aluminum version of the PI essentially, with potential for port work to be done. So my question is, is the powerband on the Typhoon essentially the same as that of the PI? If so, I'd rather replace my PI intake with one of those just so I don't have to keep doing it. But, I can buy two and a half PI intakes for what the Typhoon costs, so I'm mildly torn.
Woodman is offline
post #57 of 71 (permalink) Old 08-13-2019, 06:45 PM
Admittedly I’m judging the Dorman by the fact that when compacting the thing for trash pickup the thing shattered like porcelain to my big hammer, while the all plastic broken Ford one needed a couple sawblades to accomplish the same.
If you were operating a taxi or livery fleet, and bought a few Panthers at an auction, would you just send them all out as is? When you’re running an operation for 30 years and have memories of the Ford plastic intake recall debacle and the lost fares and consequential maintenance, it’s not a risk they’re willing to take and the cost pays for itself in short enough order. Fleets use them because they’re easy to get and quick to service, and reliable enough to get probably 100k miles before they start leaking. Good enough. Not better.
Fleets know better, of course, better than to buy one used. In my anecdotal experience the Dormans tend to stay on the cars until they’re dismantled and crushed, Ford intakes are missing and reused(how do I know? the telltale separate gaskets remaining on the heads). Hmm.
Ford intakes are made either in the US or Canada, I don’t recall which since I don’t have any lying around here anymore. I’m sure someone will chime in and verify.
@Woodman , the Typhoon is a Chinese PI with casting flash in the runners. Portable, yes, worth porting, no. Better options at that price point.
Woodman likes this.
post #58 of 71 (permalink) Old 08-13-2019, 08:05 PM Thread Starter
That's no way to analyze materials. I doubt you destroyed both anyway just to hear them crack. Fake News.
Bluebird
post #59 of 71 (permalink) Old 08-13-2019, 08:24 PM
You're actually Jeremy, aren't you?
If not, You must be the dumbest individual we've seen here for a while.
And that's saying something.
Woodman likes this.
Grog6 is online now
post #60 of 71 (permalink) Old 08-13-2019, 08:46 PM
I made it pretty clear I destroyed them both to fit in the trash, because both were trash. Would have been more convenient for me if the Ford one immediately shattered into a dozen conveniently small pieces like the Dorman instead of bouncing across the garage like a basketball when I hit it.
Good luck.
Similar Threads
Brand new aftermarket 96-97 header panel Embalmer Parts For Sale 4 05-16-2014 01:34 PM
AOD aftermarket torque converter, 4R70W aftermarket conveter, Iron 8.8 IRS diff 3.23 PearlBirdSC Parts For Sale 6 01-12-2012 09:43 PM
Brand New 4.6L (PI) INTAKE MANIFOLD T_Bird_Babe Parts For Sale 4 08-16-2007 01:35 PM
Aftermarket heads, intake manifold, etc? 95XR7 Engine - 4.6L & 5.4L 15 07-28-2005 02:39 AM
Ford vs. aftermarket brand Water pump ccornett Engine - 4.6L & 5.4L 5 07-14-2003 07:04 PM
