New center-out exhaust setup pictures - TCCoA Forums
post #1 of 7 (permalink) Old 07-01-2003, 08:46 PM Thread Starter
Custom 4.6 Specialist
Anthony J. Lewis's Avatar
Cool New center-out exhaust setup pictures
I'm a little delayed in posting these as promised a while ago. We did things a little differently than anything I've seen previously, and thought it may be of interest. I'm using my Cardomain page for the pix, to save bandwidth on the BBS. Thanks for visiting.
AJL
http://www.cardomain.com/member_page...279045&page=12
Gen-IV Eaton MP90 blower, Allen Rev-II 9psi kit with AFCO 27" Intercooler Heat Exchanger making 12+psi, Custom '08 Renegade Racing/Romeo Aluminum Shortblock, Bored .020 over [285cid], CNC ported heads, Stainless Ferrea Valves & guides, Crower Stage II Blower Cams Diamond Forged Pistons, Manley H-Beam Forged Rods, Polished 8-Bolt Crank, 38lb Injectors, Screamin' Demon Coil Packs, T-45 Five-Speed Cobra Trans Conversion, FRPP 3:73 Rear, Custom Drive Shaft, JBA SilverCeramic Headers, 85mm Billett Straight-Shot MAF/Tube, BBK 75mm T/B, Cobra Oil Pump, Mark VIII Oil Pickup, Federal Mogul Main Bearings, Custom 2.52" non-slip blower pulley, Innovator's West 6% Billett Overdrive Main Pulley SCT Flash custom 4-Position tuning program.
Anthony J. Lewis is offline
post #2 of 7 (permalink) Old 07-13-2003, 08:31 PM
Looks nice.I did a center exit Mark three years ago with dual 3 inch pipes.I had two seperate mufflers and no cats though.
I got a lot of compliments on it, I'm sure you will too.
http://www.maxrpm.com/meats.jpg
unstoppable is offline
post #3 of 7 (permalink) Old 07-14-2003, 03:25 AM
WaLieN's Avatar
Send a message via AIM to WaLieN
Do you get a lot of interior resonance? how big are your pipes after the 3rd cat?
☼1997 Ford Thunderbird LX - 4.6L -K&N Panel Filter-Steeda U|D Pulleys-Steeda 180* Thermostat-Removed Intake Silencer-Polyurethane IRS Bushings-Tranny Cooler-Urethane Tranny Mount
☼1993 Mazda RX-7 Touring [VR] - Rotary Power rebuilt turbos & motor w/ 3mm Apex Seals - PWR Radiator - PFS Cat-Back - RB Intake Duct w/ K&N Panel - Manual Boost Controller - KG Differential Brace - Gotham Engine Torque Brace - Aluminum 45mm Front STB - B&M Short Throw Shifter - PFS Column Mounted Boost Gauge - Falken Azenis ST115s [235/40ZR17] on Speedy Mashie Silvers
WaLieN is offline
post #4 of 7 (permalink) Old 07-14-2003, 03:37 AM
Cougar Pilot
BlackCat94's Avatar
FRPP driveshaft??
BlackCat94 is offline
post #5 of 7 (permalink) Old 07-14-2003, 08:57 AM
Overkill Fetish Freak
Extremely Ghey-Leen
Dr. FrankenCougie is offline
post #6 of 7 (permalink) Old 07-14-2003, 12:43 PM
Send a message via AIM to slayer
I like that center out exhaust... How much did it cost, if you don't mind saying...
Sam
slayer is offline
post #7 of 7 (permalink) Old 07-16-2003, 09:21 PM
Cougar Pilot
BlackCat94's Avatar
Originally posted by Dr. FrankenCougie
http://members.tccoa.com/bigscott/Cougie/ExtremeS.jpg
Extremely Ghey-Leen
Boy didn't you know that those is handy for keeping rodents from out your cylinder heads?
