Plugs for high compression 5.4 - TCCoA Forums
post #1 of 6 (permalink) Old 07-04-2003, 09:58 AM Thread Starter
gecko2424's Avatar
I need the part number for the best plugs for my 5.4. I'm using the motorcraft copper plugs for the lightning now gapped at the usual.
I have 11.1:1 compression and get a nasty bit of rattling at low RPM's and some pinging at WOT with 93 octane.
Suggestions?
SOLD!!!!
5.4 block from 99 expedition bored .20 over
Forged crank/Manley Rods/JE flat tops/chromemoly rings and Steeda Underdrives
P&P PI heads (by me) w/ 3 angle valve job w/copper gaskets with ARP studs/bolts and One piece lightning cams
80mm Pro-M MAF and Cut & welded '95 4.6 intake
Jmodded Trans & Trac-loc pumpkin (Cobra) 3.27
Raxles, ADDCO 1 1/4", Eibachs, JL Braces
18" CEC type 169 wheels w/ 245/40 front 255/45 rear
gecko2424 is offline
post #2 of 6 (permalink) Old 07-04-2003, 06:43 PM
Mushroom Stamp Layer
seabass's Avatar
What plugs are you running now?
seabass is offline
post #3 of 6 (permalink) Old 07-04-2003, 09:51 PM
RIP Jake
Leland Jacobson's Avatar
Just bought some Denso Iridiums from Dennis....Mine are for pending blower conversion, but you could check with him as he's got the non -blown ones too, and see what he thinks... be prepared for sticker shock tho' LOL
.................................................. .................................................. ....................................'95 LX 5.4 a labor of love...
Leland Jacobson is offline
post #4 of 6 (permalink) Old 07-05-2003, 09:29 AM
seabass's Avatar
I'd stay shy of the Iridiums...but that's just me.
seabass is offline
post #5 of 6 (permalink) Old 07-05-2003, 12:14 PM
RIP Jake
I'm useing copper cores now, and they seem to do a good job, but hey, I'll try anything once (well, maybe there are a few exceptions)
post #6 of 6 (permalink) Old 07-06-2003, 03:15 AM
Drag racing with Jesus
NGK's "TR-6" = I run the TR-5's in mine - TR-6's are even colder
Just Passin Thru !!!
Curtis Carter - July 14, 1954 to June 4, 2006 -- RIP Brother, you will be missed
MODS=SCT tuned/J-Mod/Trans Cooler/Dyno max Cat-Back/NgkPlugs/Mac cold air/March UD's/FRPP aluminumcarrier3.73's "SOLD CAR"
PI cams + PI intake manifold w/adapter plate
Mark VIII Convertor/80mm L-Maf/70mm TB
Mark VIII 1 piece shaft/Cobra R' wheels/
Kumhos 235/60/16 - White leather w/ blue
cloth seats - white face gauges in 95 cluster
LST MN-12 is offline
