4.6l = eec-v=obd-II - TCCoA Forums
post #1 of 12 (permalink) Old 07-05-2003, 10:45 AM Thread Starter
4.6l = eec-v=obd-II
Does the 94 4.6l is odd-II and if so where would be the plug...
thanks guys!
Bullit_AMP
Finally got the bird!
94 lx 4.6l
Bullit_AMP is offline
post #2 of 12 (permalink) Old 07-05-2003, 11:08 AM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
You have OBD-II.
As for the plug, I would check under the glove compartment (in that area). I'm not feeling too well at the moment, so te exact location is eluding me...
Nonetheless, you have OBD-II...someone will chime in with the proper location and procedure...
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #3 of 12 (permalink) Old 07-05-2003, 11:39 AM
JustinH's Avatar
on my 95 it is under the glove box. It will have a rubber cover over it.
JH
JustinH is offline
post #4 of 12 (permalink) Old 07-05-2003, 11:54 AM
Trumpeter Extraordinaire
IronChopz's Avatar
1994 model with 4.6L engine has the connector under the glove compartment.
IronChopz is offline
post #5 of 12 (permalink) Old 07-05-2003, 03:09 PM
MagerThom's Avatar
Question
I'm not an EEC expert....but am I remembering correcty (or not) that the
'94's and maybe the '95's were not fully OBD-II compliant in some way?
Mager Thom
1997 AED Thunderbird LX
287RWHP 345RWTQ
"It's ALL about air flow...eveything else...is tuning..."
MagerThom is offline
post #6 of 12 (permalink) Old 07-05-2003, 03:36 PM
Yep, that's what I have heard also.
The 94/95's are not a fully compliant version of OBD-II. But they are pretty close. I don't know what the differences are, but I think 96+ are fully compliant. It may have something to do with the ignition being external vs. internal on the new models. Just a guess.
Hope that helps.
69 F100 LWB w/460 Engine
post #7 of 12 (permalink) Old 07-05-2003, 03:50 PM
MagerThom's Avatar
Thumbs up
Just found it....
A-Train's post of 3/20/03.....
http://forums.tccoa.com/showthread.p...562#post116562
Mager Thom
287RWHP 345RWTQ
post #8 of 12 (permalink) Old 07-05-2003, 06:22 PM Thread Starter
thanks you guys.
does it mean it can be program with a tuning/code reader device?
or must it be a piggy back chip?!
Bullit_AMP
94 lx 4.6l
post #9 of 12 (permalink) Old 07-05-2003, 06:27 PM
JustinH's Avatar
you can swap the eec out for a reprogrammed eec, or you can use a piggyback chip.
JH
JustinH is offline
post #10 of 12 (permalink) Old 07-05-2003, 06:31 PM Thread Starter
where can i find the eec-v codes...they're not in the tech section...i just found eec-iv code...i assume they're not the same
Bullit_AMP
94 lx 4.6l
post #11 of 12 (permalink) Old 07-05-2003, 07:50 PM
If you are talking about the OBD-II codes try these links.
http://www.obdii.com/codes.html
http://www.actron.com/code_lookup/index.php
Or just do a web search under "OBD-II Codes". There's a lot of information about how each code is broken down.
post #12 of 12 (permalink) Old 07-06-2003, 09:32 PM Thread Starter
thank's! that really help!
Bullit_AMP
94 lx 4.6l
