Timing Chain cover Question - TCCoA Forums
post #1 of 9 (permalink) Old 07-07-2003, 06:57 PM Thread Starter
I have a timing chain cover off of the '99 F-150 4.6, and when I hold it in front of the one on the engine in my cougar, it looks *VERY* close... the only difference seems to be that the idler pully for the F-150 has three bolts holding it to the cover, and the on on the car has two visable from the top. Will the cover from the F-150 work when I do the '02 explorer swap (I was going to rebuild the '99 block, but the consensus was that it would cost about as much as, or more than, an almost new '02 explorer engine from Greenleaf).
As reference, the part numbers on them are:
'99 F-150 cover - F65E-6C086-AD
'95 Cougar - F3AE-6D080-AC
Best times:
Cougar281 is offline
post #2 of 9 (permalink) Old 07-07-2003, 07:24 PM
Warped's Avatar
I'm no expert on the 4.6 but I would assume that since they are different part numbers that something is different about them such as the idler pulley as you mentioned and possibly other things you can't see. Speaking from experience swapping engines though, it's always easier to do a total engine swap rather than piece-work one together from numerous other resources. If Greenleaf can get you the whole thing ready to drop in the car then that's the route I'd take. You'll certainly have more hair when you're done!
Warped (not twisted!)
"Pity for the guilty is treason to the innocent." - Richard Rahl
"Democracy is two wolves and a lamb voting on what to have for dinner.
Liberty is a well-armed lamb contesting the vote." -Benjamin Franklin
Warped is offline
post #3 of 9 (permalink) Old 07-07-2003, 08:27 PM Thread Starter
Well... The engine from Greenleaf is ALMOST ready to drop in... a few parts need to be changed on the engine, such as the fuel rails, timing chain cover (I think), it seems fuel lines are a good idea too, so the originals can't crimp because the supply/return are in a different place than the '95...
Best times:
post #4 of 9 (permalink) Old 07-07-2003, 09:06 PM
Warped's Avatar
ah ok, can you use your original Romeo timing covers then? Maybe a call to Max at 5 Star can settle the differences in the timing covers? Just food for thought.
Warped is offline
post #5 of 9 (permalink) Old 07-08-2003, 12:08 AM
NRL
Real Ultimate Goatse Hunter
NRL's Avatar
Send a message via AIM to NRL
There is one bolt by the water pump that will be off by 1/4" or so. It will not work.
NRL is offline
post #6 of 9 (permalink) Old 07-08-2003, 07:05 AM
Banned for LIFE - SW
Blown94SC's Avatar
Send a message via Yahoo to Blown94SC
Wont fit. you need a 92-95 front cover
Blown94SC is offline
post #7 of 9 (permalink) Old 07-08-2003, 07:10 AM
Recidivistic Procrastinator
Blown94SC is correct. You need the 94-95 cover. You can use the one on your engine.
94 LX 4.6
Hibernating...
Engine built by Jim O'[email protected] Racing
I live with "fear" everyday, sometimes she lets me race...
Cam94 is offline
post #8 of 9 (permalink) Old 07-08-2003, 07:11 PM Thread Starter
Ok. I was just hoping to be able to have all (or most) of the parts that would need to be changed done before I even take the original engine out...
Best times:
post #9 of 9 (permalink) Old 07-08-2003, 10:22 PM
Blown94SC's Avatar
Keep an eye on Ebay as I got the correct front cover for 14 bucks... 13 of it was shipping....
