How far down should the temp sensor be screwed in? - TCCoA Forums
post #1 of 5 (permalink) Old 07-08-2003, 07:29 PM Thread Starter
NRL
Real Ultimate Goatse Hunter
NRL's Avatar
Send a message via AIM to NRL
http://misc.ug-pro.com/Pictures/Car/TempSensorGap.jpg
Look at that picture. Thats how far I got it right now. Im having problems getting it down farther because the edge of it are hitting the intake. I've been using vice grips and putting as much force as possible till a corner of it gets passed the intake, then I can finger tighten it until it gets to the next corner. I don't want to get to the point where im putting alot of force on it thinking the corner is catching the intake again, when its actually in all the way. So how far is far enough?
NRL is offline
post #2 of 5 (permalink) Old 07-08-2003, 07:55 PM
Equal Opportunity Offender
Fuel man's Avatar
Exclamation
First of all; You should have ground some clearance for the sender, it would have made a cleaner install. Second; It doesn't look like there is any sealer on the threads. You need sealer to well,seal from leaks.And third; with all these things corrected tighten the sender with a socket if possable till it is just snug.
Those brass fittings are easy to brake off.
Just use your head and try again
Fuel man~~~
No air silencer
Gutted Violin Case
Bosh Platinums
Modded Trans W/ATF+3
Bring Back 80s' Metal Rock
Fuel man is offline
post #3 of 5 (permalink) Old 07-08-2003, 08:01 PM
Not sure how far is far enough but I'll tell you what I would do. Use a good amount of thread sealer ( if you have'nt already) just in case it's not far enough. Another idea is to grind some material off the intake. It does'nt seem like you would need to grind off much because you are able to turn the sensor with out gouging a hole through the manifold. I know these are not the answere you were looking for but I think they will work.
2000 GT engine
Nakamichi CD 500, Nakamichi MB 70 in dash cd changer, three Nakamichi amps (1000 watts), 10 inch sub, MB Quart speakers (4 5x7 and 2 6x9)
2003 Mustang Mach 1
"The fast ones always ride for free"
Andrew Wood (R.I.P.) Mother Love Bone
BlackBird is offline
post #4 of 5 (permalink) Old 07-08-2003, 08:23 PM Thread Starter
NRL
NRL's Avatar
Fuel man~~~
1. Its not leaking, so i'm not worried about thread sealant
2. You would think you could get a socket on it, but the edge of it hits the intake, so there is definatly no room for the socket wall.
You would think the intake would be made to accept the temperature sensor without any grinding.. that is unless the 96+ cars use a different sender then the 94-95 cars.
NRL is offline
post #5 of 5 (permalink) Old 07-08-2003, 10:24 PM
Banned for LIFE - SW
Blown94SC's Avatar
Send a message via Yahoo to Blown94SC
If it isn't leaking and the car is running correctly it's in far enough.
Blown94SC is offline
