Flushing the Radiator...... - TCCoA Forums
post #1 of 5 (permalink) Old 07-09-2003, 02:00 AM Thread Starter
stadium13's Avatar
I'm new with engines so this may be a stupid question... But anyways, Does anyone know the PROPER step by step for flushing the radiator on a 96 t-bird 4.6 V8?? Thanx...
stadium13 is offline
post #2 of 5 (permalink) Old 07-09-2003, 06:42 AM
Rolling-Thunder's Avatar
Do you want to flush the radiator only, or the entire system?
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #3 of 5 (permalink) Old 07-09-2003, 05:13 PM Thread Starter
stadium13's Avatar
I should flush the entire system... This t-bird spent most of it's life in N.C. with the extreme cold.. Now down in Fla It's going through 90+ degree days for the next 6 months... So how do you do this? Thanx...
post #4 of 5 (permalink) Old 07-10-2003, 09:02 AM
Trumpeter Extraordinaire
IronChopz's Avatar
It's relatively simple. Here's a couple articles that are on the Articles pages:
Cooling System Draining Article
Heater Core TSB/Coolant System Bleeding Info (at the bottom of this, there's a "Tip O' D Day" that you should follow).
Read through them a couple times. All in all, the procedure is simple. Just make sure to follow the procedures in these two articles.
IronChopz is offline
post #5 of 5 (permalink) Old 07-10-2003, 05:26 PM Thread Starter
stadium13's Avatar
Thanx... I'll check them out.....
