3.73 install - TCCoA Forums
post #1 of 8 (permalink) Old 07-09-2003, 08:12 AM Thread Starter
95BLKLSC's Avatar
3.73 install
I bought a new 3.73 trac-loc unit for a 99 cobra. I'm going to be doing this install in the next few weeks. Any tips, tricks, or suggestions for this install? Estimated install time? I'm not doing this by-myself, I am going to have another set of hands helping me. I have good mechanically ability so what do you think?
95BLKLSC is offline
post #2 of 8 (permalink) Old 07-09-2003, 08:42 AM
The Great Obucina's Avatar
http://www.tccoa.com/articles/gears/index.html#
it shouldnt be that hard, get a new set of poly bushings from mn12performance.com.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 8 (permalink) Old 07-09-2003, 10:36 AM
Banned for LIFE - SW
Blown94SC's Avatar
Send a message via Yahoo to Blown94SC
I thought the stangs had 31 spline side gears while we had 28. Or are you planning on swapping the side gears?
Blown94SC is offline
post #4 of 8 (permalink) Old 07-09-2003, 10:50 AM
To my knowledge, the only Cobra IRS that has 31 spline are the new ones (2003?) with the supercharged engine.
All the other Cobra IRS's should be a straight bolt in for the MN-12's.
Someone correct me if I'm wrong.
69 F100 LWB w/460 Engine
post #5 of 8 (permalink) Old 07-09-2003, 11:07 AM
Send a message via AIM to pa_dan Send a message via Yahoo to pa_dan
'00 cobra R=31spline, 01' cobra=31spline,no 02' cobra's made, 03'cobra=31spline.
THE ONLY ONE THAT WORKS IS THE 99' COBRA. Read the FRPP cataloge, it list it for the 99' cobra. Doesnt work on newer cobras.so make sure it's for a 99 car and your all set.For the record the 99 came with 3.27 gears. If the seller claims it had 3.73's stock ask him to pull the cover.then count the teath on both ring and pinion, then devide them to make sure. Some people dont care who the con, so be one step ahead. Good luck.And dont forget a chip to adjust the shift points, and a new drive shaft is a good idea.
94 4.6L Lx, 04 exploder engine awating instalation
88 Mustang LX 5.o 5spd stock
70 Mustang mach 1 Ex-drag car
66 Mustang convertable getting a new 302.
Pa mustang/ford forum
http://www.svtcobraltd.com/cgi-bin/ikonboard.cgi?
pa_dan is offline
post #6 of 8 (permalink) Old 07-09-2003, 11:21 AM Thread Starter
95BLKLSC's Avatar
Thanks for all the responses! It a 28 spline, and it's for a 99. And it does have 3.73's, it's a new ford motor sport assembly, sorry I didn't make that very clear. I ordered it from 5 star ford. Looking forward to getting these in!
95BLKLSC is offline
post #7 of 8 (permalink) Old 07-10-2003, 11:26 PM
Just did this swap three weeks ago. Pretty simple. Thing's I messed up.. I broke the plastic vent tube piece. Oh well. I took the rear caliper off the one side to pull the axle. Good hint, rent the damn tool for the caliper piston.... I tried to use the needle nose pliers that my manual suggested... no luck. I also decided to use a synthetic oil... the FRPP 3.73 unit had alot more fluid then I realized... took a bit to drain out. Other then that, pretty simple swap. Any other questions, I'll do my best to help. I have some pics of the swap in progress if you need.
Juicer is offline
post #8 of 8 (permalink) Old 07-11-2003, 05:07 AM
Aaron_T's Avatar
Well, depending on how your exhaust is, and how many ppl you have helping, you may wanna see if somone has a differential jack (attatchment for a regular floor jack). Summit has one for $50, but if you know someone, or can rent (or just buy), it would probably make it A LOT easier. All in all pretty easy. There was a post by Silver95bird not too long along that should help.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
