Good Ol Gas - TCCoA Forums
post #1 of 5 (permalink) Old 07-11-2003, 07:05 AM Thread Starter
Good Ol Gas
Alright, Ive posted serveral times. I replaced almost everything that could cause the problem.
New plugs, Wires, PCV, and o2's
What else can be cause my problems?
I had P0172 for awhile but i can it removed. What can it be?
I get less then 225 on a full tank highway...
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #2 of 5 (permalink) Old 07-11-2003, 09:21 AM
Trumpeter Extraordinaire
IronChopz's Avatar
Ouch....a lengthy list of things to check came up when I checked the 1996 Service Manual:
Diagnostic Trouble Codes (DTCs) P0171 bank (1) (cylinder #1) and DTC P0174 bank (2) indicate the fuel/air ratio is too lean. The fuel adaptive system is at the rich correction limit.
DTC P0172 bank (1) and DTC P0175 bank (2) indicate the fuel/air ratio is too rich. The fuel adaptive system is at the lean correction limit.
DTCs HO2S Reference list:
HO2S-11 = DTCs P0171 and P0172
HO2S-21 = DTCs P0174 and P0175
Possible causes:
Fuel system:
Excessive fuel pressure.
Leaking fuel injector(s).
Leaking fuel pressure regulator.
Low fuel pressure.
Contaminated injector(s)
Induction system:
Air leaks after the MAF.
Vacuum leaks.
Restricted air inlet.
PCV system.
Fuel purge system.
Improperly seated dip stick.
EGR:
Leaking gasket.
Stuck open EGR valve.
Leaking diaphragm.
Base engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2S's.
Check air intake for leaks, obstructions and damage.
Check air filter, air filter housing for blockage.
Verify integrity of the PCV system.
Check for vacuum leaks.
IronChopz is offline
post #3 of 5 (permalink) Old 07-11-2003, 10:02 AM Thread Starter
grrr how i check these things? I can't find a leak anywhere. all my fluids are great
2004 F150
KrAzyT is offline
post #4 of 5 (permalink) Old 07-11-2003, 12:18 PM
Silver95Bird's Avatar
Pull the new plugs on the bad side - my hunch is a fuel injector(or more) is hung wide open. Some of the plugs will be really black and sooty compared to the rest of them, it should be a giveaway.
Silver95Bird is offline
post #5 of 5 (permalink) Old 07-11-2003, 12:32 PM
JustinH's Avatar
I suggest you take it to a shop who knows what they are doing if you can't do these things.
Good luck with it.
JustinH is offline
