Exhaust quote: Good or Bad? - TCCoA Forums
post #1 of 7 (permalink) Old 07-12-2003, 11:21 PM Thread Starter
46cougrrr's Avatar
Okay guys, I just got back from the exhaust shop. He gave me a quote and I wanted to run it by you guys to get input from experts. He quoted 265.85 to cut from a few inches before the 3rd cat back off, and put an x-pipe there with two 2" pipes running through the stock tunnel in the tank and around the pumpkin, one pipe on each side to the back to weld in two mufflers( I provide those). He said he'd need two 15' lengths of pipe, $39/each, he'd make his own x-pipe. An example I was shown looked like 4 90 degree bends cut and welded together, and aluminized pipe coated with some heat paint or something like that. He says 15$ for misc hangers and the rest for labor. Bring it in the morning and he'd have it ready by noon. He also said i'd need to find mufflers that have a center output and offset output and that the output pipe would necessitate having the exhaust hang down at an angle on each side toward the center. He said that two inch pipe is all that would fit through the tank tunnel without rubbing. Now the plans for this car are to rebuild the block with forged everything, P&P'd NPI heads with custom cams, and the 9# AED kit ( unless better and more economical(read: cheaper) kits can be suggested). Will two 2" pipes support the flow I need without causing extreme bottlenecking/backpressure or should i try to convince him to go bigger. My mechanic says 2.5 inch is too big and will kill low end but later on (money providing) i plan to grab a set of kooks 2.5" headers and custom downpipes with aftermarket cats. Should I go with this deal or what? Any input would be great. Thx in advance
DD: MG 03 Cobra, 21psi M122 (GT500) blower swap
99 GT Auto Roller for sale 10 pt Wolfe Racecraft cage, 16gal fuel cell, 90% of interior, just needs rear seat delete, rolls on stock suspension except tubular k & MM C&C plates $3500
46cougrrr is offline
post #2 of 7 (permalink) Old 07-12-2003, 11:30 PM
Refrigerator Raider Hater
GreenBird's Avatar
good price for the work, but I would use a Dr. Gas X pipe, and 2.25 pipe after the X
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 7 (permalink) Old 07-12-2003, 11:31 PM
Flying Thunder
weswing04's Avatar
Send a message via AIM to weswing04 Send a message via Yahoo to weswing04
i think thats a decent price...but too small for your future plans. you'd need AT LEAST 2.25 if not 2.5 to let it breathe properly. people have done 2.5" just fine..he's just intimidated
weswing04 is offline
post #4 of 7 (permalink) Old 07-12-2003, 11:43 PM Thread Starter
46cougrrr's Avatar
Will dual 2.5" fit through the gas tank tunnel? i want to route it to keep as much clearance as possible and not mottle up the sound
post #5 of 7 (permalink) Old 07-13-2003, 04:03 AM
Stephen C's Avatar
Send a message via AIM to Stephen C
2.5 all the way with 2 40 series flowmasters up front
It's so hard to find good help these days. It took me a week to convience a shop that this exhaust could be done.
In fact to have the same put on my cat I had to bring in the bird to prove to them it could be done.
Cheers
Dare 2 B Different
1997 T-Bird 281
1993 Cougar 302
Stephen C is offline
post #6 of 7 (permalink) Old 07-13-2003, 11:53 AM
My exhaust guy charged me $325 for 2.5" pipes from the first cats back to the mufflers (true duals, no x pipe)... he hung Borla muffler back where the stock ones are, only at a 45 degree angle to keep the pipe straighter... i lucked out and got the Borlas for the same price as dynomax the whole job was $600...
96 GoldBird
N/A:
96 GoldBird is offline
post #7 of 7 (permalink) Old 07-13-2003, 12:51 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
If you don't mind driving about an hour or so..lemme know..I'll hook you up with the shop that did my duals here..
Shoot me PM,and I'll get you the contact info.
JL
Fuelly
Johnny Langton is offline
