Pulley Part # - TCCoA Forums
post #1 of 5 (permalink) Old 07-13-2003, 04:33 PM Thread Starter
Pulley Part #
I searched the threads and i didn't see any thing that mentioned a Part # for the Steeda underdrive pulleys that would direct fit onto a '95 4.6 cougar/thunderbird. If anybody would happen to have this part # it would be appriciated. Oh and i was just wondering what the term "piggyback" means. i saw it in a few of the threads and i wasn't sure what that meant. and is better than the steedas pulley system or what is the difference. i just want to know what i'm buying for sure before i find out that the steedas won't work without modifacations. thanks for the help.
MercCat_XR7
Flowmaster Cat-Back Tuned Exhaust, , K&N Filterpanel, Richard M Intake Tube, MSD 8.5mm Superconductor Wires, MSD Racing Ignition Coils, Steeda Underdrive Pulleys, TransGo Shift Improver Kit, 3.73 FRPP Pumpkin Kit, 2700 Torque Converter, Deleted Third Cat, Removed Air Silencer, Alpine Head Unit, 2 Alpine 12" Type R Subs, Concept 1100 Amp, 17'' AT Italia Chrome Inox Wheels
MercCat_XR7 is offline
post #2 of 5 (permalink) Old 07-13-2003, 04:52 PM
The Steeda P/N would be 701-0001, that will work without any modifications. A piggy-back setup re-uses the original Harmonic Balancer, the Steeda system builds one into the Crank Pulley. The Steeda system is generally regarded as the better setup, however it costs more.
'94 Thunderbird LX(4.6L)
94SVTBird is offline
post #3 of 5 (permalink) Old 07-13-2003, 05:33 PM Thread Starter
I tried looking up the part # 701-0001 for the steeda pulleys on summit and jegs but it didn't come up with anything. where can i oreder these off of? thanks.
MercCat_XR7
post #4 of 5 (permalink) Old 07-13-2003, 05:55 PM
You can order them directly through Steeda, http://www.steeda.com, hope this helps
post #5 of 5 (permalink) Old 07-13-2003, 07:37 PM
The Great Obucina's Avatar
MercCat_XR7
The Steeda pulleys are manufactured by ASP, so if Jegs or Summit lists the ASP pulleys for the 4.6L Mustang those are ones you want also.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
