Cam and Bore over questions.... - TCCoA Forums
post #1 of 3 (permalink) Old 07-14-2003, 03:38 AM Thread Starter
Send a message via AIM to whoinow Send a message via Yahoo to whoinow
I am looking for performance cams. I have, of course, the Romeo heads and was wondering if there were performance cams for these heads. If they do exist, is it work the upgrade? I know there is the PI deal from 99+ ford vehicles, will those cams work in the Romeo heads? If so, performance increase? Also, I read there is a bore over kit for the mustang motor, from 281 to 302. The kit included rods, pistons, rings, bearings, and crank. Does anyone know of this kit or something similar? I am trying to get the most out of this N/A motor. Any suggestions for major perfomance increases would be great
1996 Thunderbird
Goal: V8 Super Coupe or Cobra.
whoinow is offline
post #2 of 3 (permalink) Old 07-14-2003, 08:28 AM
Overkill Fetish Freak
Our stroker kits are designed to increase the stock 281 cubic inches to a beefy 302 cubic inch torque monster (with a .020” overbore). These kits are available for both standard bore (3.552”) and .020” overbore (3.572”) blocks. Each kit includes: ModMax Pro Billet 4340 crankshaft, ModMax Forged 4340 H-Beam Rods, ModMax custom pistons, heavy duty pins, double spirolox, ModMax Plasma Moly file-to-fit rings, King Hi-Perf Rod Bearings, and Federal Mogul Main Bearings. The kits are also available with two differently configured pistons for high compression (10:1 to 10.6:1), or with lower compression (9:1 to 9.5:1) for boosted applications. PLEASE NOTE: THESE KITS MUST BE BALANCED BEFORE INSTALLATION. As well as our shelf kits, we have several options available to tailor a kit to your needs. Please see the section at the end of this listing for options.
ModMax 990-25299 $3,200.00 kit
3.552” (std) bore Stroker Kit with high compression (10:1 to 10.6:1)
ModMax 990-25302 $3,200.00 kit
3.572” (+.020”) bore Stroker Kit with high compression (10:1 to 10.6:1)
ModMax 990-25300 $3,200.00 kit
3.552” (std) bore Stroker Kit with low compression (9:1 to 9.5:1)
ModMax 990-25303 $3,200.00 kit
3.572” (+.020”) bore Stroker Kit with low compression (9:1 to 9.5:1)
ModularPerformance.com
Dr. FrankenCougie is offline
post #3 of 3 (permalink) Old 07-14-2003, 12:18 PM Thread Starter
ahhh, that was the information I was looking for. Thank you. Now anyone on the cams? worth it? available?
1996 Thunderbird
whoinow is offline
