Timing Chain Aligned...Then not... - TCCoA Forums
post #1 of 10 (permalink) Old 07-16-2003, 07:59 AM Thread Starter
rustyul's Avatar
Ok, I'm going to sound like a non-mechanical person here, but I'm just seeking a little reassurance....
I put the timing chains on my engine last night...Crank keyway at the 9:00 position. It wasn't too much trouble getting the bright links on the chain aligned with the timing marks on all the gears.
The moment of truth arrives when I slowly turn the crank, feeling for any valve to piston clearance. I feel none, and continue to turn the crank a full revolution. I look to see if the timing marks line back up. They don't, so I continue to turn, and turn, and turn, looking to get all the marks lined back up. I must have turned the crank 20 or 30 times, but the marks never did come back to the bright links.
I'm thinking at some point, if I kept turning the crank, the marks would have to line up eventually.
Does all this sound normal, or should I take the chains off and start over?
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #2 of 10 (permalink) Old 07-16-2003, 09:56 AM
Refrigerator Raider Hater
GreenBird's Avatar
I don't think they should line up after you've cranked it...it only matters when putting them on.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 10 (permalink) Old 07-16-2003, 10:14 AM
Overkill Fetish Freak
The cam/crank marks will line up after like 10-15 revs but I don't think the chain links will line up tho.
-Scott
Dr. FrankenCougie is offline
post #4 of 10 (permalink) Old 07-16-2003, 11:03 AM
OK, I'm confused. Wouldn't the links have to line up after x amount of rotation.
They are connected by a chain and gears, right? Unless they jump a tooth or something, wouldn't they have to eventually line back up? If you follow the bright link from the top/cam gear, all the way down to the crank gear, then back up to the same location on the top gear again, wouldn't the bottom/crank bright link have to be in the same location?
Not arguing, but scratching my head trying to figure how they couldn't eventually line back up.
I’m following this post closely as I’ll be installing my gears/chains in the near future.
69 F100 LWB w/460 Engine
post #5 of 10 (permalink) Old 07-16-2003, 11:56 AM Thread Starter
rustyul's Avatar
I'm thinking they will eventually line back up, but after how many rev's, I don't know. I'm tempted to turn the crank in reverse to undo what I did last night, just for my own reassurance. Since there didn't seem to be any interference between the valves and the pistons, I still think I got it right, but I just want to double check myself.
rustyul is offline
post #6 of 10 (permalink) Old 07-16-2003, 12:37 PM
You always want to turn clockwise never counter clockwise.
post #7 of 10 (permalink) Old 07-16-2003, 12:37 PM
AEDM8's Avatar
Yes they will come back after A LOT of revolutions. Now dont take this as you did it right, I dont know that, but rest assured the links will line up again eventually if you did it correct. I would say if you have turned it a few times with no clearance issues, then you should be OK.
I turned mine over till everything lined up again. Took me FOREVER.
AEDM8 is offline
post #8 of 10 (permalink) Old 07-16-2003, 05:15 PM
Renegade
chadg's Avatar
As did I. They do line up after a long long time.
-Chad
Down for the count
chadg is offline
post #9 of 10 (permalink) Old 07-16-2003, 07:44 PM
scott's Avatar
I would like to add to that.........LONG LONG LONG LONG LONG TIME.
There is a ratio involved here and the number of links in the chain plays a part not just the number of teeth. It's like a 'hunting" tooth ratio where they don't want to develope a wear patern. Take a rear end and mark two teeth as they meet then see how many time you have to turn it for them to line up again.........LOTS.
Same idea.
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
post #10 of 10 (permalink) Old 07-16-2003, 09:52 PM Thread Starter
rustyul's Avatar
Thanks guys....I appreciate the feedback. I put the cover back on assuming that I had things lined up OK. My arm was starting to hurt from so much crank turning. Now I know what the deal is....
rustyul is offline
