Crank pulley - TCCoA Forums
post #1 of 5 (permalink) Old 07-19-2003, 04:11 PM Thread Starter
Crank pulley
I just got my steeda pulleys yesterday but don't we need a special pulley puller for the crank pulley. i'm not sure about it but i could have sworn that i heard that u need a puller to get the pulley off the crank on the 4.6 motors. how hard is it to get off? thanx for the info.
MercCat_XR7
Flowmaster Cat-Back Tuned Exhaust, , K&N Filterpanel, Richard M Intake Tube, MSD 8.5mm Superconductor Wires, MSD Racing Ignition Coils, Steeda Underdrive Pulleys, TransGo Shift Improver Kit, 3.73 FRPP Pumpkin Kit, 2700 Torque Converter, Deleted Third Cat, Removed Air Silencer, Alpine Head Unit, 2 Alpine 12" Type R Subs, Concept 1100 Amp, 17'' AT Italia Chrome Inox Wheels
MercCat_XR7 is offline
post #2 of 5 (permalink) Old 07-19-2003, 05:04 PM
NRL
Real Ultimate Goatse Hunter
NRL's Avatar
Send a message via AIM to NRL
Yes, you need a puller for it. And it isn't hard to do at all.
NRL is offline
post #3 of 5 (permalink) Old 07-19-2003, 05:38 PM Thread Starter
would i be able to get a puller at one of the local shops or would i have to order one? plus about how much do u think they run money wise? thanks.
MercCat_XR7
post #4 of 5 (permalink) Old 07-19-2003, 05:43 PM
scott's Avatar
You should be able to get one at your local parts store for around $15.
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
post #5 of 5 (permalink) Old 07-19-2003, 08:51 PM
RIP Jake
Leland Jacobson's Avatar
Hint: when you change that harmonic balancer/pulley , take a few extra minutes and remove fan and shroud unit to give yourself that little extra room. you'll be glad you did....
Leland Jacobson is offline
