has anyone here done the 99-02 cobra intake swap? - TCCoA Forums
post #1 of 21 (permalink) Old 07-27-2003, 02:08 PM Thread Starter
I am planning on doing the swap on a 94 4.6. I know I need to do the PI head swap and upgrade the fuel system. Is there any other major mods/problems. What kind of power gains are people seeing from doing this swap?
puffsc is offline
post #2 of 21 (permalink) Old 07-27-2003, 03:42 PM
miller1995's Avatar
Seems you are a bit confused. The cobra motor is DOHC while the 4.6 from a bird or cat is SOHC meaning the intakes are not interchangable. I am asuming you have a SOHC motor because of the PI heads question but if you have a mark 8 this swap may be possible i don't know for sure.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #3 of 21 (permalink) Old 07-27-2003, 07:32 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
He probably means the Bullitt intake?
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #4 of 21 (permalink) Old 07-27-2003, 09:22 PM
Kaptn' Obvious's Avatar
Send a message via AIM to Kaptn' Obvious Send a message via Yahoo to Kaptn' Obvious
I think he was talking about this
I was looking at it too..
I dunno if it'll fit or not?
Mostly stock...
For now...
Kaptn' Obvious is offline
post #5 of 21 (permalink) Old 07-28-2003, 09:58 AM
Tx_Cat's Avatar
I dont think It will fit, maybe cause of its for DOHC and our car is SOHC, besides isnt it DOH bigger than SOHC?? That $hit looks BIG.... But hey, you never know. Someone correct me please if I am wrong..
Tx_Cat is offline
post #6 of 21 (permalink) Old 07-28-2003, 11:59 AM
Midnight's Avatar
Send a message via AIM to Midnight
I saw that too. I was also wondering if that would fit. But I figured that the intake was for a dohc and that it wouldn't match up.
Midnight is offline
post #7 of 21 (permalink) Old 07-28-2003, 12:01 PM
Tx_Cat's Avatar
Thats what I am concerned to..... We need the big guys to help us on that topic..
Tx_Cat is offline
post #8 of 21 (permalink) Old 07-28-2003, 12:29 PM
Overkill Fetish Freak
You done did figured it correct like.
Dr. FrankenCougie is offline
post #9 of 21 (permalink) Old 07-28-2003, 12:35 PM
Tx_Cat's Avatar
LOL I knew it . Thanks Dr.
Tx_Cat is offline
post #10 of 21 (permalink) Old 08-28-2003, 05:03 PM
Send a message via AIM to slayer
So would that intake fit a '93 Mark Engine?
Sam
slayer is offline
post #11 of 21 (permalink) Old 08-28-2003, 05:36 PM
Stephen C's Avatar
Send a message via AIM to Stephen C
Sure it will fit!!!!!!
Once you put on some 99+ DOHC heads that is
Sam
That intake is for the tumble port heads, and no it won't bolt to your car either. However I do believe the 96-98 intake will fit.
Cheers
Dare 2 B Different
1997 T-Bird 281
1993 Cougar 302
Stephen C is offline
post #12 of 21 (permalink) Old 08-28-2003, 10:08 PM
ITT-BIRD's Avatar
It looks to be the Bullit intake, not he Cobra intake ... if it is the bullit intake, it will fit the SOHC but you may need P&P or PI heads to get the full potential from it. If its a cobra intake like it says, but i think they should clarify if its the cobra or bullit; DOHC or SOHC 4.6s, then it wont fit our engines... SOHC.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #13 of 21 (permalink) Old 08-28-2003, 10:33 PM
The Great Obucina's Avatar
that pic looks nothing like the Bullitt manifold. Another thing to consider..the DOHC head has 2 intake ports and 2 exhaust ports....how the hell would a DOHC manifold match up to a SOHC head..its common sense think about it.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #14 of 21 (permalink) Old 08-28-2003, 11:02 PM
330Bullitt's Avatar
Send a message via AIM to 330Bullitt
joseph
It has nothing to do wityh the amount of valves as to why it wont work, as it has the same amount of ports from the intake. The differance is that the DOHC heads are larger and the ports that the intake bolts to is closwer together because of this, so the intake is actually narrower in size than a SOHC intake.
~Kris
95' Nissan 240sx
94' Mazda RX-7
330Bullitt is offline
post #15 of 21 (permalink) Old 08-29-2003, 07:30 AM
The "Box" in the upper right of the pic shows just how narrow the 4V intake is.
-Scott
post #16 of 21 (permalink) Old 08-29-2003, 10:30 AM
JustinH's Avatar
is that twin screw a present for the mark?
JustinH is offline
post #17 of 21 (permalink) Old 08-29-2003, 10:44 AM
Yes, The only thing better then getting screwed once is twice.
post #18 of 21 (permalink) Old 08-29-2003, 11:05 AM
So I apologize, i am a bit slow. If it is the Bullit intake will it work on a 93/94 Mark DOHC? Or no still. If so is it because of the tumble port heads?
Sam
slayer is offline
post #19 of 21 (permalink) Old 08-29-2003, 11:07 AM
No...Still.
post #20 of 21 (permalink) Old 08-29-2003, 11:24 AM
330Bullitt's Avatar
No...Still.
Because the Bullitt intake is designed for the SOHC the ports are further apart.
~Kris
95' Nissan 240sx
94' Mazda RX-7
post #21 of 21 (permalink) Old 08-29-2003, 11:38 AM
Stephen C's Avatar
My spider sense tells me there is great confusion in this thread. So lets map things out shall we?
96-98 Cobra > 4V DOHC intake WILL NOT FIT A SOHC 2V MOTOR. However it will work on a M8.
99-02 Cobra > 4V DOHC intake. Ford redid the heads for the later model Cobras so this intake isn’t a bolt on for any M8. Once again………. WILL NOT FIT A SOHC 2V MOTOR
Bullitt > 2V SOHC intake. This was used on the Bullitt Mustang which was produced after all Mustangs started using the PI heads. This intake will NOT work on any MN12 as a direct bolt on. You will have to switch to PI heads first in order to put one on. WILL NOT FIT A DOHC 4V MOTOR
SVO > This is a FRPP intake. It was released before the PI heads so it is made to fit NPI SOHC heads and the SVO heads. Please keep in mind this intake sells somewhere between 1300 and 1500 dollars. THIS WILL NOT FIT ANY 4V DOHC HEAD OR 2V SOHC PI HEAD.
Thank you and have a nice day
Cheers
Dare 2 B Different
1997 T-Bird 281
1993 Cougar 302
