Can someone post a wiring diagram for the temp sensor? - TCCoA Forums
post #1 of 6 (permalink) Old 07-31-2003, 12:40 PM Thread Starter
Smile Can someone post a wiring diagram for the temp sensor?
I replaced my 95 4.6 with a 99 grand marquis engine and the temp gauge is not working. I replaced the sensor and it still isnt working. I think it maybe either the wiring or the gauge is gone. Any help would be great.
99 NPI 4.6
SC Springs/Sway Bars
Trac Loc
J-Chip/L-Maf sensor
2.5 DynoMax exhaust with Hi-Flow Cats.
silvershot is offline
post #2 of 6 (permalink) Old 07-31-2003, 12:50 PM
Does the GrandMarquis intake have the second sensor for the guage?
The T'Bird has two sensors: One for the EEC (ECT) located on the left (?) of the water crossover, and the sensor for the temperature gauge on the right (?) of the water crossover. (I may have them reversed).
I'm not trying to be smart or anything, (you probably know about the two sensors) but just asking.
69 F100 LWB w/460 Engine
post #3 of 6 (permalink) Old 07-31-2003, 01:17 PM Thread Starter
Yes I have them both hooked up correctly the temp on the left and the eec on the right. Im thinking it may be a break in the wiring between the actual sensor and the harness.
99 NPI 4.6
Trac Loc
J-Chip/L-Maf sensor
post #4 of 6 (permalink) Old 07-31-2003, 11:58 PM
If you short the sensor, the gauge should go to maximum temp.
Don't do this to the PCM temp sensor - you'll go into overheat limp-home mode.
bill_s is offline
post #5 of 6 (permalink) Old 08-01-2003, 07:36 AM
Overkill Fetish Freak
If you have the sensor installed in a plastic intake make sure the body is grounded. I just wrap a wire around it with a clamp over the wire and then use the nearest ground.
-Scott
Dr. FrankenCougie is offline
post #6 of 6 (permalink) Old 08-08-2003, 01:36 PM Thread Starter
-Scott
That was it. As soon as I gounded the base of the sensor it started to work.
99 NPI 4.6
Trac Loc
J-Chip/L-Maf sensor
