plugs reading lean? - TCCoA Forums
post #1 of 2 (permalink) Old 07-31-2003, 08:09 PM Thread Starter
Send a message via AIM to ruffledfeathers
plugs reading lean?
I changed out my old 12c's today and the old ones were verry white and chalky
The tech article says if the plugs are that way they are too hot and the car is
running lean.
I think 12c is one of the coldest plugs around for this car.
As far as running lean how can I solve this problem?
I have a dennis chip should I see if he can richen the mixture some?
I replaced the wires also. I had stock wires but I went with frpp 9mm this tme.
It feels like it has its pep back now.
94 LX 4.6
SC GFX , Suspension Techniques springs bilstein struts
R.P.C. tuning, 80mm mMAF
2 steps colder plugs, 9 mm wires 180 stat1 piece alum. driveshaft, 3.73 gears
2.5 inch Xpipe no 3rd cat , no mufflers
PI Stallion 9 inch 3k stall converter
March underdrive pullies
Zex dry Nitrous kit 75 hp for now
[email protected] with no traction !SOLD!
93 mustang notch 5.0
ruffledfeathers is offline
post #2 of 2 (permalink) Old 08-01-2003, 05:51 PM Thread Starter
ttt
94 LX 4.6
post #3 of 2 (permalink) Old 08-01-2003, 06:10 PM
J.Miller's Avatar
As long as your air filter and MAF are clean adn you are running high octane fuel you can have a little rich tune. The best solution will be to get on a dyno and have it dialed in.
J.Miller
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
