March 1150 u/d pulleys and stock serpantine belt - TCCoA Forums
post #1 of 5 (permalink) Old 08-03-2003, 10:51 PM Thread Starter
Well I picked up my u/d pulleys, March 1150's will I need to get a smaller belt or will the stock belt work. Just want to have all that I'll need when I start so I won't have to walk halfway across town to get a new belt. I notice that quite a few people have gone with this set or the Steeda's, Thanks, Rick
98 4.6 SOHC, J-Modded, B & M 24K Tranny Cooler, Cold Air Intake, 76 MM MAF, RM Tube, March 1150 U/D Pullies, Poly Bushings, Air Bags, MK VIII Brakes and Wheels, Trak-Lok w/ 3.55's MK VIII Flex plate and Marauder T/C. Now that it can go, it'll be time for show.
thndrchiken is offline
post #2 of 5 (permalink) Old 08-04-2003, 12:23 AM
The Great Obucina's Avatar
stock serp belt fits.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 5 (permalink) Old 08-04-2003, 12:35 AM
NRL
Real Ultimate Goatse Hunter
NRL's Avatar
Send a message via AIM to NRL
Also, the pulleys are bigger then stock, so even if you did need a different sized belt, it would be longer, not shorter.
NRL is offline
post #4 of 5 (permalink) Old 08-04-2003, 04:05 AM Thread Starter
Thanks, just wanted to be sure. The documentation in the box says that some applications require a smaller belt. These will probably be going on Wed. after that all I really have left is the exhaust and I'll be happy for a while at least.
post #5 of 5 (permalink) Old 08-04-2003, 11:22 AM
also, if you are concerened about length, i left my OE alternator pulley on, i bought mine used and it didnt come with a spacer.
joseph
