Fan Keeps running - TCCoA Forums
post #1 of 3 (permalink) Old 08-05-2003, 08:06 PM Thread Starter
Fan Keeps running
Fan runs for a long long time now since i replaced my old 95 4.6 with a 99 grand marquis engine. When i had the older engine the temp gauge ran between the blue notch and the N in norm, now its between the O and M in norm. After the car starts up it just run none stop.. I have the original T-stat from the Grand Marquis could that be the problem or something else??
99 NPI 4.6
SC Springs/Sway Bars
Trac Loc
J-Chip/L-Maf sensor
2.5 DynoMax exhaust with Hi-Flow Cats.
silvershot is offline
post #2 of 3 (permalink) Old 08-05-2003, 10:21 PM
MadRussian's Avatar
Send a message via AIM to MadRussian Send a message via MSN to MadRussian Send a message via Yahoo to MadRussian
Aren't you supposed to use a 180* thermostat with a chip?
-andrey
96 LX 4.6L
13.215 @ 103.09
MadRussian is offline
post #3 of 3 (permalink) Old 08-05-2003, 10:46 PM
Not necessarily.
98 4.6 SOHC, J-Modded, B & M 24K Tranny Cooler, Cold Air Intake, 76 MM MAF, RM Tube, March 1150 U/D Pullies, Poly Bushings, Air Bags, MK VIII Brakes and Wheels, Trak-Lok w/ 3.55's MK VIII Flex plate and Marauder T/C. Now that it can go, it'll be time for show.
thndrchiken is offline
