will a DOHC off of a Mark VIII fit a SOHC? - TCCoA Forums
post #1 of 4 (permalink) Old 07-17-2002, 07:18 PM Thread Starter
T-BIRDS281E's Avatar
Question will a DOHC off of a Mark VIII fit a SOHC?
I just was wondering or would you have to swap the heads to go with it?
T-BIRDS281E is offline
post #2 of 4 (permalink) Old 07-17-2002, 08:57 PM Thread Starter
sorry forgot the intake part in that ?
I ment will a DOHC intake plenumfit the SOHC it is off of a Mark VIII?
post #3 of 4 (permalink) Old 07-18-2002, 04:10 PM
4 Cam Bird's Avatar
The Mark Engine uses actuators to open the long and short tubes at different RPM's doesn't it? This would be a nightmare to make happen without the Mark computer, I really doubt that it is possible to make it function properly if it does fit. For the time it would take you could problaby have the whole DOHC motor in.
2011 CTS-V Wagon
4 Cam Bird is offline
post #4 of 4 (permalink) Old 07-18-2002, 06:01 PM
Refrigerator Raider Hater
GreenBird's Avatar
I believe...
The thing you speak of is the IRMCs. There are delete kits, but you'd lose alot of low-end torque.
On a sidenote, my SHO has a dual runner intake, and the secondaries are controlled by vacuum. Might be possible to make them vacuum actuated.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
