Need Help with 95 Bird - TCCoA Forums
post #1 of 8 (permalink) Old 07-17-2002, 11:37 PM Thread Starter
Send a message via AIM to reaper
Angry Need Help with 95 Bird
I need alot of help with my 1995 4.6. It has been acting up alot lately. First it started to throw codes about once a month when pushed hard saying my #2 bank is running lean. After reading the code book I come to find this is the right hand bank. I believe this is the passenger side bank. Anyways, that code now pops up weekly, and I can't get it to go away. I look at the car and everything looks fine, it performs fine, it just throws codes. I was told it could be the Fuel Pressure Regulator but I am not positive it is the problem and since I'm a poor college student going back to school in a month, I can't afford to buy and install parts that don't fix the problem. Is there any way to tell if that IS the problem? Also can an aftermarket adjustable regulator be used in place of the stock regulator with the same results? And how do I go about adjusting the pressure?
Now for the next problem. I have a problem in the transmission or around it. When under light throttle especially at highway speeds I feel a clunking in the footweels of the car by the transmission tunnel. It is obvious the vibrating/thumping is coming from the transmission area, but what could it be? I checked for loose heat shields on the Cats and that is not a problem. Could it be a transmission mount or somethin more serious like a torque converter or the transmission itself? Also, how difficult is it to replace a transmission mount if it is broken, and how do I find out if it is or not? Thanks for any help you can give me on this.
reaper is offline
post #2 of 8 (permalink) Old 07-18-2002, 07:30 PM
krusher
Guest
Posts: n/a
Had the same problem
Alright, had a 1995 bird that threw system too lean on both banks. More often than not its a vacuum leak. Replace the $5 gasket in the intake manifold and it might fix the problem. Also check all your vacuum hoses to see if they are connected ot cracked or anything else... Other than that you should replace your fuel filter. Its under the passenger side door. A clogged filter can lower your pressure enough to register a code. I'd check the regulator last. Good luck.
post #3 of 8 (permalink) Old 07-19-2002, 09:51 AM
Clean the MAF, tech article. If that doesn't fix it I would look at O2 sensors also. High mile cars that have run poorly for a long time ruin them.
If you only have one bank consistently lean, you may just have dirty injectors.
Buy the top end injector cleaning solvents and double up on the mix. Valvoline or Techron are my favorites.
rm
Most fun I ever had was with the Texas TCCOA guys making power and drag racing.
Now I am using a 2001 BMW M3 Vert for fun.
RichardM is offline
post #4 of 8 (permalink) Old 07-19-2002, 10:07 AM
Peter M's Avatar
One of my first mods was the MN12 MAF mod- boring the MAF sampling tube(just say no!). My car would consistantly throw right side lean codes and few if any left side codes, until I went back to a stock MAF. I agree, clean the MAF and check for a possible vac. leak. I would lean(no pun intended ) toward the MAF as the culprit.
Peter
SOLD 1996 4.6l Thunderbird-(fast) PI intake, custom exhaust, Bullet-Resistant Tranny™, blah, blah, blah
2007 VW GTI-(faster) United Grey, 18" wheels, APR stage 1 chip, and... uh... that's it for now.
________________________
..this space for rent..
Peter M is offline
post #5 of 8 (permalink) Old 07-20-2002, 02:02 PM
95LX's Avatar
Peter...
Do you have a website? I just wanted to see a closeup pic of your car. Looks tempting in the little icon there. Thanks.
Jim
95LX is offline
post #6 of 8 (permalink) Old 07-22-2002, 09:00 AM
Peter M's Avatar
I have to confess. The icon is a Photoshop touchup. It's only silver. BUT- one day I would like to do that paintjob. (sorry-no website right now, but if you want I can email a larger version)
Peter
Peter M is offline
post #7 of 8 (permalink) Old 07-22-2002, 03:55 PM
95LX's Avatar
Hey if you could, I'd still like to see a larger version of that. It looks nice anyway.
Jim
95LX is offline
post #8 of 8 (permalink) Old 07-22-2002, 04:46 PM
Peter M's Avatar
Look in the Misc. section of the Forums. I'm posting a poll on it...
Peter
Peter M is offline
