Will this work? - TCCoA Forums
post #1 of 16 (permalink) Old 12-19-2003, 08:45 AM Thread Starter
Will this work?
http://www.corral.net/forums/showthr...hreadid=415222
without a chip?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #2 of 16 (permalink) Old 12-19-2003, 11:27 AM
toofast4u's Avatar
Send a message via Yahoo to toofast4u
Thats the same one I'am running on my cat without a chip runs fine.
fast as fast can be you'll never get me!!
K&N panel filter,Flowmaster cat back,Cowl induction hood,Hrbacek white face flamed gauges,Spoiler,75mm Pro-M bullet maf,MSD Super Conductor plug wires,Steeda Underdrive pulleys,Clear corners,FFRP 3:73 trac lock rear,Steeda poly IRS bushings,22r plugs,180 t-stat,Apten SCT chip,Summit fuel presurre gauge,Performance auto valve body,Updated acumulators,Deep sump tranny pan,Civic intake tube,97 center console,just a start more to come!!!
Sittin in my spare room awaiting install... Jba headers,03 Mustang t/c, and flexplate,Comp Cam Valve Spings,PI Explorer Motor,New Pi Intake,Holley High Flow Fuel Rails with Braided Lines,Mark VIII Driveshaft,Crower Cams,Trick flow pleum,Art downtubes
toofast4u is offline
post #3 of 16 (permalink) Old 12-19-2003, 02:34 PM
About2beBAD's Avatar
Agreed. If it's calibrated for 19# injectors, that's what you have. No need for a chip.
You'll notice at least a slight difference in performance as well. The more you have done to your car, the more you will benifit from a larger MAF.
It's a good investment. I'd go for it.
About2beBAD is offline
post #4 of 16 (permalink) Old 12-19-2003, 02:35 PM
benefit* I HATE spelling errors!! lol
Damn it.
post #5 of 16 (permalink) Old 12-19-2003, 03:28 PM
Boom.
Palmguy's Avatar
You do know that you can edit your posts, right?
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #6 of 16 (permalink) Old 12-19-2003, 03:32 PM
02 Explorer Pioneer
timb's Avatar
While it may work as "the man" would say it's bad to lie to the EEC which is all you are doing by calibrating it to injectors.
Birdless
timb is offline
post #7 of 16 (permalink) Old 12-19-2003, 04:19 PM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Agreed.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #8 of 16 (permalink) Old 12-20-2003, 02:10 AM
Silver95Bird's Avatar
First of all, did Pro-M make the tube chrome like that, or did this guy make his own chrome tube and drop in the sensor? If he homemade it, pass. If it's a factory piece, get the flow sheet for it and send that in when you get your chip done. I wouldnt change the MAF without a chip to account for it.
Silver95Bird is offline
post #9 of 16 (permalink) Old 12-20-2003, 09:51 AM
toofast4u's Avatar
It's a pro-m unit I have one myself.
post #10 of 16 (permalink) Old 12-20-2003, 09:59 AM
5.0 Chero's Avatar
But since it is calibrated for #19lb Injectors you wouldn't be lying to the puter would you? The factory injectors are #19lb?????
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #11 of 16 (permalink) Old 12-20-2003, 12:06 PM
Sheepish
AverageJoe's Avatar
Well yes, because the computer is calibrated for the flow charactistics of the stock MAF. It doesn't know the transger function of the new MAF and that can still throw everything off.
post #12 of 16 (permalink) Old 12-20-2003, 12:28 PM
TCCoA Founder
Sir William's Avatar
Repeat after me...."You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors...You CANNOT calibrate a MAF for injectors."
Now. Think it's sunk in yet? You calibrate your EEC for your MAF and your injectors. Then and ONLY then will you have a proper system. Anything else is lying to the EEC which will give marginal results at best.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #13 of 16 (permalink) Old 12-20-2003, 01:30 PM Thread Starter
So basically get a MAF around the time of the dyno tune or chip purchase?
Thanks for everything!
2004 F150
KrAzyT is offline
post #14 of 16 (permalink) Old 12-20-2003, 01:46 PM
Sheepish
AverageJoe's Avatar
Correct.
post #15 of 16 (permalink) Old 12-21-2003, 02:04 AM
toofast4u's Avatar
You still buying the pro-m? Thats a good deal.
post #16 of 16 (permalink) Old 12-21-2003, 03:07 AM
VicRattlehead's Avatar
exactly! dont fool the computer cause it knows.
SuperchipsCustom, tuning by the people that know.
CMP Drag Racing
VicRattlehead is offline
