code P1443? - TCCoA Forums
Old 12-22-2003, 03:01 PM Thread Starter
GUS
GUS's Avatar
code P1443?
I have a 96 t-bird 4.6 with a CE light. I cleared the codes and changed plugs(it had the wrong ones) and wires, cleaned the MAF, pulled the silencer. When I started the car, it ran alot better and no CE light. On the way to see my girl the light came back on ! I scanned it this time and got this P1443 code, what is it and how do I fix it!!
93 Mark VIII
4.30s with trac-loc, chip,3000stall,exhaust..so far
GUS is offline
Old 12-22-2003, 03:23 PM
02 Explorer Pioneer
timb's Avatar
Try using the code and the search button. You can also look up codes at this site
http://www.obdii.com/codes.asp
It happens to be Evaporative Emission Control System Control Valve code
From the search button here are all the threads
http://forums.tccoa.com/search.php?s...der=descending
Birdless
timb is offline
Old 12-22-2003, 03:44 PM Thread Starter
GUS
GUS's Avatar
Thanks, I used the search but did not put in "P1443"so I did not see it. This board is use the search button crazy.
93 Mark VIII
GUS is offline
Old 12-22-2003, 04:39 PM
16secondp71's Avatar
I just had a ranger into the shop with the same code, I diagnosed it as an purge flow sensor, but that code can also be tripped by broken vacuum lines, purge solanoid, and about 10 other things. You're gonna have trouble diagnosing the problem with no scan tool.
96 P71 Crown Vic Project:Qwick Vic
-trac-loc/3.73's
-NOS "NOSzle" direct port kit
-2 1/2in. exhaust/deleted rear cats/02 sensors
-forged internals
-ported/polished PI heads
-Aluminum Cobra block
-FRPP headers
-stall converter
16secondp71 is offline
Old 12-22-2003, 07:21 PM
The Great Obucina's Avatar
we arent search button crazy, we just get the the same questions every few months and past posts with detailed instructions and part numbers.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
Old 12-23-2003, 07:54 AM
Rolling-Thunder's Avatar
Not to mention the fact that since it is ALREADY posted, you don't have to wait for someone else to post it for you.
I don't think anyone is trying to do anything other than HELP, when they mention to use the search button.
Most people that are looking for info., usually want it sooner, than later.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
Old 12-23-2003, 08:23 AM
02 Explorer Pioneer
timb's Avatar
Definitely.....which is why I posted the search link with all the threads and the querry I used to get them
Birdless
timb is offline
Old 12-23-2003, 08:34 AM Thread Starter
GUS
GUS's Avatar
Thanks for the replys, I really didn't mean to come off as an ***. I just wanted to state that I "did use the search button" but i guess I didn't use it well enough.
93 Mark VIII
GUS is offline
Old 12-23-2003, 09:04 AM
Trumpeter Extraordinaire
IronChopz's Avatar
P1443 Threads
According to the 1996 PC/ED Manual, P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
Damaged EVAP canister purge valve.
Damaged PF sensor.
Here's a diagram to assist you in what to check:
Good luck to you.
IronChopz is offline
Old 12-23-2003, 09:21 AM Thread Starter
GUS
GUS's Avatar
thanks IronChopz
93 Mark VIII
GUS is offline
Old 12-23-2003, 09:46 AM
Awaiting E-Mail Confirmation
Warrior455's Avatar
I have the same code being displayed as well. Gus, let us know what fixes the problem for you. Thanks!
Warrior455 is offline
Old 12-23-2003, 09:52 AM Thread Starter
GUS
GUS's Avatar
I will be glad too I can't believe how much better the "correct" plugs made, and that was the first set of modular wires I have ever installed...wasn't that bad when i realized it was easier to remove the alt. instead of working around it.
93 Mark VIII
GUS is offline
Old 12-29-2003, 11:21 PM
Hey IronChopz how you been? Where does that - PF sensor - live?
Chris....................
ChrisW01 is offline
Old 12-31-2003, 07:20 PM
Hello again. Just thought I'd let you all know after checking the service, diagnostic
and wiring manual that theres is no PF (purge flow) sensor in the 95/96 T-bird
and Couger.
ChrisW01 is offline
Old 01-01-2004, 08:46 AM
IronChopz's Avatar
Hi, Chris...
Apologies for not responding sooner...been offline for a couple days. Good question about the PF sensor. I wasn't able to locate anything (yet) about it for the 1996 vehicles, either.
Later!
--Pete
Old 01-02-2004, 04:33 AM
Tinfoil hat wearer
azreael344's Avatar
Send a message via AIM to azreael344 Send a message via Yahoo to azreael344
i got that same code on mine when they changed over to the oxygenated gas here in Md. back in like Sept. I cleared the codes a few times but after i started running 93 octane it hasn't come back..........I thought that was kinda wierd but whatever works right. My car is finicky i guess
azreael344 is offline
Old 01-02-2004, 06:48 AM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
http://forums.tccoa.com/showthread.p...highlight=1443
I even got the part numbers in this one...
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
Old 01-02-2004, 05:17 PM
Originally posted by IronChopz
Hi, Chris...
Later!
--Pete
Thanks! Have read some of the more recent posts with their links. It
would seem from some of those posts that some cars have a PF sensor.
(or so their owners believe) Its an interesting question maybe this thread will
generate some discussion. I know my 95 does not have a PF sensor.
Chris........................
ChrisW01 is offline
Old 03-03-2004, 01:45 PM
would this hender performance at all?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
Old 03-03-2004, 04:28 PM
Matt C's Avatar
My 95 had that code for a long time and it made no difference in performance. After clearing the codes a few times it would only come back when I was almost out of gas. So now I just keep it above an 1/8th of a tank and have no problems
1997 LX Sport..Eibachs & KYBs...245/50s on Eagle Alloy 16x7s...SC rear sway bar...94 SC seats...Mark VIII ds...SCT tuned by Lasotta Racing ...Dirty Dog Marauder converter... Trans by Supergordo
Matt C is offline
Old 03-04-2004, 07:00 AM
anyone got actual pictures?
2004 F150
KrAzyT is offline
