question about cam sprockets - TCCoA Forums
post #1 of 2 (permalink) Old 12-28-2003, 10:54 AM Thread Starter
Question question about cam sprockets
i'm in the process of putting my engine back together, after my heads got screwed up, and i'm replacing the cam sprockets....the ones that i got from O'Reilly don't seem (to me, at least) that they will work.
the stock sprockets have a really deep-cutting "key" that bites into the camshaft, but the replacements only grab the groove on the shaft by about 2 - 3 mm. is that sufficient to keep them from shearing off the "key" on the replacments under hard acceleration?
everything on my car is currently stock
95ThundaChik'n is offline
post #2 of 2 (permalink) Old 12-28-2003, 03:19 PM
scott's Avatar
That's normal and it will work fine just be sure to tighten them to the recommended
torque. ( 80-90 FT LBS I think )
97 LX sport 4.6
T-45 5 speed, 3.73 with track lock; PI heads, 02 MAF, #24 injectors,190 fuel pump,JBAs, 75mm TB. ect,ect.; Aluminium drive shaft. 13" PBR Brakes; Dennis chip, lowered with solid sway bar bushings and hiem joints; console mounted E brake WITH the cup holders; C&l Plenum, Steeda U/D; VERY big radiator; 2.5" duals, Magnaflows;B&M ripper shifter; bla..bla...bla...
Lincoln MKVIII 93.........sweet ride.
Bag-less, lowered.
scott is offline
