C&L True Flow Plenum - TCCoA Forums
post #1 of 11 (permalink) Old 12-30-2003, 02:20 PM Thread Starter
Drag racing with Jesus
Question C&L True Flow Plenum
Has anyone tried this new Plenum for 1996-97 4.6's
"C&L 4.6 True Flow intake Plenum"
On a stock headed and intaked motor ??
Curtis Carter - July 14, 1954 to June 4, 2006 -- RIP Brother, you will be missed
MODS=SCT tuned/J-Mod/Trans Cooler/Dyno max Cat-Back/NgkPlugs/Mac cold air/March UD's/FRPP aluminumcarrier3.73's "SOLD CAR"
PI cams + PI intake manifold w/adapter plate
Mark VIII Convertor/80mm L-Maf/70mm TB
Mark VIII 1 piece shaft/Cobra R' wheels/
Kumhos 235/60/16 - White leather w/ blue
cloth seats - white face gauges in 95 cluster
LST MN-12 is offline
post #2 of 11 (permalink) Old 12-30-2003, 08:05 PM
97ThunderCat's Avatar
i have not but if you go to http://www.stangnet.com there is alot of info on it. bunch of guys have it on and are seeign power across the entire band, soewhere in the 10 hp ballpark. they say there is a huge seat of the pants difference as well. according to some people who claim to be in the new C&L is also workign on the lower intake as well. i really hope so. there is also a plenum otu called the dragon also, i think http://eee.modularfordpowerhouse.com has it. it is also good from what i am hearing.
97ThunderCat is offline
post #3 of 11 (permalink) Old 01-12-2004, 10:41 PM
No More BS
HotRod88LSC's Avatar
Hey there Curtis, Everything is going good man.
That, C&L Plenum and a 75mm TB picks up a 5hp gain across the board, not just peak. Just came back from the dyno and saw it work on a 94 with stock heads mad 217rwhp.
1988 Lincoln Mark VII
Paxton Novi 1000 6psi kit, 30lb injectors 73mm C&L, MAF converted A3M, gt-40's, Felpro headgaskets, 1.7 Cobra RR's, typhoon intake,1 5/8 shorty headers, off road x-pipe, and full mandrel catback, electric fan, 3.73's, TKO 500, pro 5.0 shifter
372.4hp / 394.6tq 5psi
Rest in Peace Joel R. Bender.
July 30, 1979 - March 26, 2006
HotRod88LSC is offline
post #4 of 11 (permalink) Old 01-19-2004, 05:50 PM
Moderator & Teksid Whore
guitar maestro's Avatar
on modular depot, a guy made +8.9 HP and +13.9 ft-bs with a '03 GT........so im guessing for 96-97s with the better intake than the 94s, it will pick up between 5-9 HP and probably around 5-9 ft-lbs.........i'm thinking of picking up the C&L plenum/Accufab 70 or 75mm TB sometime before summer comes along
Edit: this reminded me of the article in the June '03 issue of MM&FF of the ported stock (GT) plenum by Ben Alameda Racing, which netted 10 HP and 14.9 lb ft of torque w/ stock TB on a Dynojet......for only $159 + $59 core charge.....seems like a better deal than the TB/plenums that sell for $400 a set.......what do you guys think?
EDIT #2: nevermind about EDIT #1 above.....just found out thru modular depot that those claims were never duplicated on an N/A car.....seemed too good to be true considering how much the aftermarket plenums/TBs were gaining
guitar maestro is offline
post #5 of 11 (permalink) Old 01-19-2004, 11:35 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
try the search feature, we just had a thread that is still active on this topic buddy....
http://forums.tccoa.com/showthread.p...threadid=33253
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #6 of 11 (permalink) Old 01-20-2004, 01:03 AM Thread Starter
BUDDY = Ha Ha Ha "Now the veterans show up" when this post was
listed on December 30th not
January 17th
I forgot I haven't received my TCCoA Badges "stickers" yet.
post #7 of 11 (permalink) Old 01-20-2004, 12:01 PM
Send a message via AIM to jjjustin17 Send a message via Yahoo to jjjustin17
i thought to get that u need the 96 97 intake and u cant put it on a 94- 95?
green 95 thunderbird lx 4.6
mods-- clear corners, k & n filter, lebra, 97 intake tube. flowmasters.
mods to install-- saleen wing, sc side skirts. hopefulls-- new heads, intake, sc rear bumper, cowl hood, cobra r's, lower the car,
jjjustin17 is offline
post #8 of 11 (permalink) Old 01-20-2004, 12:48 PM
BIG PETE's Avatar
I never actually dynoed mine with my BBK 75mm throttle, but that was the first mod that I did to my Cougar along with the intake pipe and UPR Big Mouth filter. I did put the GTech to it before the mod and an hour later after the install and entered the same vehicle weight and drove down the same stretch of road. It said that I picked up 9 RWHP. Now, I know it's a GTech, so it's not completely accurate, but that same GTech told me that I consistantly had 128 RWHP stock when the dyno said 117, so I think there is some validity to the data, eventhough it's not hard fact.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #9 of 11 (permalink) Old 01-20-2004, 02:47 PM Thread Starter
Justin
You are correct 1996 and up only - Also there is (2) different plenums
1996 - 2001 and 2001 and up.
Evaluating all response I beleive this is a great bang for the buck !!
$179.00 & Free Shipping from www.crmotorsports.com
Thanks All
post #10 of 11 (permalink) Old 01-20-2004, 05:16 PM
what limited bird was saying is that it is a 94 but it has a pi manifold on top of it but still has stock heads and we gainrd 5 across the boardon a stock motoered 94 except for comps cams
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #11 of 11 (permalink) Old 01-20-2004, 05:32 PM
BIG PETE's Avatar
The only thing is that you have to add another vacuum oulet for your power brakes. Also, the rear vacuum outlet is 3/8" while the stock is 1/4". If you buy an adapter, than can be fixed, and a I drilled and tapped a NPT fitting to 3/8" barbed for the brakes. I then used some transmission cooler hose to attach the brakes to the permanent 3/8" fitting on the piece, while I ran my PCV to the barbed fitting.
Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
