Place to mount rear engine chains besides bellhousing? - TCCoA Forums
post #1 of 7 (permalink) Old 01-01-2004, 08:43 PM Thread Starter
Banned
billabong132132's Avatar
I'm pulling my engine without tranny so it looks like I won't have room for the bellhousing bolts, what else can I use near the rear?
billabong132132 is offline
post #2 of 7 (permalink) Old 01-01-2004, 08:55 PM
Bean Flicker
BlackTbird96's Avatar
Send a message via AIM to BlackTbird96
How will you not have room? Those are about the only bolts you can use. On all the engines Iv pulled, It makes everything easier when you remove the intake.
BlackTbird96 is offline
post #3 of 7 (permalink) Old 01-01-2004, 09:10 PM Thread Starter
Banned
how will I be able to seperate the trans and angine enough in the car to use the bell bolts to lift the engine?
Doesn't look to me like there is room.
post #4 of 7 (permalink) Old 01-01-2004, 09:15 PM
Boom.
Palmguy's Avatar
I believe that we used a bolt into the head without any problem, but that was three weeks ago and it's kinda hazy (I've slept since then )
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #5 of 7 (permalink) Old 01-01-2004, 09:16 PM
Bean Flicker
Thread the bolt in front the valley of the block. Like you were putting them in backwards.
Iv also found that it works better if you jack the transmission bellhousing up while you lift the engine up. Otherwise, once the engine mounts clear the K-member, the transmission will just fall a few inch and land on the jack.
post #6 of 7 (permalink) Old 01-01-2004, 09:17 PM
02 Explorer Pioneer
timb's Avatar
Yep, I put a bolt in each head. Also removing the intake first will make it a lot easier to remove and replace the top 2 bellhousing bolts.
Birdless
timb is offline
post #7 of 7 (permalink) Old 01-01-2004, 10:06 PM Thread Starter
Banned
brilliant sir!
Thanks for the help guys, not a mechanical newbie, just my first time pulling the entire engine
