PCV Question - TCCoA Forums
post #1 of 2 (permalink) Old 01-02-2004, 10:13 AM Thread Starter
PCV Question
hey guys, i am in the process of putting my engine back together after having it apart for a couple of months, and i'm having trouble figuring out where some hoses go. this is on a '95 4.6L LX.
i have a PCV with dual barbs on it, and i know that it plugs into the pass. side valve cover, and one of the hoses runs to a piece of metal tubing that is mounted to the pass. side wheel well. the other hose runs to a tee, and i cannot figure out where the 2 hoses go that come off that tee. do they plug into the 2 hose barbs that are on the back of the intake manifold, one on each side? if so, i can't figure out how to route them, because of a hard plastic piece of tubing on one side of the tee, with a part # of F4SE-6C324-AB....it looks like it's too long to effectively route to the driver's side intake hose barb. it's got a couple of angles in the tubing, and no matter which way i turn it, it doesn't look like it goes anywhere.
95ThundaChik'n is offline
post #2 of 2 (permalink) Old 01-02-2004, 06:15 PM
J.Miller's Avatar
Does this help?
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #3 of 2 (permalink) Old 01-03-2004, 04:05 AM Thread Starter
well, sort of...it does confirm the answer to my question about whether or not it plugs into the intake manifold hose barbs, but i am still unable to figure out which way to turn that hard plastic piece of tubing to connect it to those barbs. does anyone have a picture of it?
post #4 of 2 (permalink) Old 01-04-2004, 07:28 AM
J.Miller's Avatar
I do not have a picture and it has been years since I saw a stock one. But as far as I remember there was a rubber hose on the end of the hard plastic hose that adapted it to the hose barb on the back of the intake. You should be able to find it at a local parts store.
J.Miller
J.Miller is offline
