Ignition coils - TCCoA Forums
post #1 of 7 (permalink) Old 01-08-2004, 02:07 PM Thread Starter
Ignition coils
My stock coils seem to be reaching the last of there life. Yes I am aware that they are just suposed to go bad. How ever, working with electronics I have learned one thing! Nothing is ever how it seems and all electronic devises can develope a mind of its own. Every couple of weeks I get a missfire after driving for an hour or so. through trial an error I have found that if I pull each plug wire, wipe, hit with rubber malet and repeate. The fowled condition returns to normal. I have changed out the plugs and wires several times over the years and the problem still hangs on So I figured I would get a good set of wires, screemon demon coils and the ACF-12C(???) spark plugs. My question is, How much over stock will this improve my performance? Thanks for your glorious knowledge ahead of time.
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
post #2 of 7 (permalink) Old 01-08-2004, 02:54 PM
Banned
billabong132132's Avatar
with a stock engine, none at all. Most guys here run factory coils with Superchargers and have plenty of spark.
Don't waste your money, just get stock coild from Dan Newman, see vendors on front page. Also try cleaning your MAF, do a search for it.
billabong132132 is offline
post #3 of 7 (permalink) Old 01-08-2004, 06:23 PM
MaleWhore
smokymance's Avatar
screaming demons dont make that big of a difference at all....they just look good....i got the demons packs and wires...not noticable diff...just back to normal car...my old wires and packs were just dead so i had to replace them....i can post a pic if u want me to show you what they look like...
smokymance is offline
post #4 of 7 (permalink) Old 01-08-2004, 11:28 PM
Refrigerator Raider Hater
GreenBird's Avatar
The test for coil packs is just an ohm meter. Your manual (Helms, Haynes, Chiltons) should all list the accectable range.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 7 (permalink) Old 01-09-2004, 07:30 AM
Send a message via AIM to zero89lx
Correct me if I'm wrong, but a better coil (better ignition system as a whole) should allow you to run with a slightly wider plug gap, increasing fuel economy if nothing else. I've also heard it increases throttle response and high-rpm power where less potent coils start to fall on their face. Now, this is based on comparing an MSD to the stock coil that's in my monte carlo, I don't know if stock t-bird coils are any better.
I hate this place! Nothing works here! The medication doesn't work! I've been here seven years! I hate this place!
zero89lx is offline
post #6 of 7 (permalink) Old 01-09-2004, 08:55 AM
02 Explorer Pioneer
timb's Avatar
The stock Tbird packs are a very hot pack. I'm running them on a blown car and have had no issues losing spark
Birdless
timb is offline
post #7 of 7 (permalink) Old 01-09-2004, 10:00 PM
FLABIRD's Avatar
[QUOTE]Originally posted by zero89lx
[B]Correct me if I'm wrong, but a better coil (better ignition system as a whole) should allow you to run with a slightly wider plug gap, increasing fuel economy if nothing else. I've also heard it increases throttle response and high-rpm power where less potent coils start to fall on their face.] You are correct. It just depends on what level of performance your at.....
Wrecked...will be parting out soon 97 thunderbird 02GT 4.6 Bullitt Intake
Kook's true dual 02 4r70w trans completely rebuilt to jerrys specs
cstm D/S 373's 11/4 bars F&R 3800lbs
240rwhp/282tq ET:14.00
"Luck happens when opportunity meets preparation"
FLABIRD is offline
