Help! Can A/C pulley bearing be replaced? - TCCoA Forums
post #1 of 13 (permalink) Old 01-09-2004, 10:39 PM Thread Starter
Exclamation Help! Can A/C pulley bearing be replaced?
Hey guys I did a search and could not find details on the ac pulley bearing. Mine is toast. Do I need to replace the whole compressor or can I just replace the pulley bearing?
Either case how difficult are these two jobs?
I need to get the car repaired tomorrow. So I am trying to figure out what I need to do.
wm_sorg is offline
post #2 of 13 (permalink) Old 01-09-2004, 11:49 PM
tbirdbrain's Avatar
You can replace just the clutch by itself. They aren't very expensive
(50-75 bucks as I recall) and less the 1 hour to do.
tbirdbrain is offline
post #3 of 13 (permalink) Old 01-10-2004, 07:03 AM Thread Starter
Thank you. Do I need any special tools, pullers, etc?
wm_sorg is offline
post #4 of 13 (permalink) Old 01-10-2004, 05:25 PM Thread Starter
I looked into the part. The parts store sells the pully with the clutch and electro-magnet $169.00. My compressor is toast. Does anyone sell just the pulley?
wm_sorg is offline
post #5 of 13 (permalink) Old 01-10-2004, 07:53 PM
Trumpeter Extraordinaire
IronChopz's Avatar
Click here and see if that's what you're looking for. It's a part listing from Advance Auto Parts. According to Yahoo Yellow Pages, there's one in Sterling, VA.
Edit added store name.
IronChopz is offline
post #6 of 13 (permalink) Old 01-11-2004, 06:41 PM Thread Starter
That's it exactly. Thank you!
wm_sorg is offline
post #7 of 13 (permalink) Old 02-02-2004, 06:07 PM
I know it's been a while since this has been active, but can this bearing be put in without a press, I'm debating weather or not to buy the bearing by itself (and install it by myself), or to buy the pulley, and bearing assembly,
V8_RWD is offline
post #8 of 13 (permalink) Old 02-03-2004, 12:55 AM Thread Starter
The bearing needs to be pressed in. I would not attempt it unless I had the correct press, etc. Otherwise, you run the risk of warping the pulley. Do yourself a favor and get a clip removal tool. There is not much room to work down there.
wm_sorg is offline
post #9 of 13 (permalink) Old 08-18-2004, 01:23 PM
kingcrab's Avatar
I hate to hijack a thread, but could you tell me how tough it is to self-install a new compressor, accumulator/drier and liquid line? (all from ackits.com of course)
I am sick of forking over money to shops for things I may be able to do myself. They say my liquid line is restricted and my compressor is on its way out. I have no cold a/c after charging with r134a. Thanks in advance for your expertise, and I apologize again for hijacking.....
Later,
Joshua
1994 3.8 na
Flowmaster 50's- True Dual
Removed Resonator & Air Silencer
K&N Cone (RAM setup)
Tint 15% rear & corners, 35% sides
kingcrab is offline
post #10 of 13 (permalink) Old 08-18-2004, 02:26 PM
girdnerg's Avatar
Man, I'm just following you all around today.
You will need the line separator tools like the ones used for the fuel filter. The zone has a plastic set for less than $10. The compressor itself is held on with 4 bolts. They are fairly easy to get at. You can do all the replacements. Then pull a vacuum on it to rid the system of moisture. Then recharge.
Rob
girdnerg is offline
post #11 of 13 (permalink) Old 08-18-2004, 02:34 PM
kingcrab's Avatar
Thanks a lot, girdnerg. What about the process? Simple disconnect, swap and re-bolt of all mentioned new parts? (Accumulator/drier, liquid line and compressor) What are the line separators for? Forgive my lack of knowledge. I am a bit green when it comes to HVAC. Thanks a lot for your help.....
Later,
Joshua
1994 3.8 na
kingcrab is offline
post #12 of 13 (permalink) Old 08-18-2004, 03:08 PM
girdnerg's Avatar
The tool is to separate the lines at each connection. Just the way Ford made them I guess. An easy example is to look where your fuel lines meet the fuel rail. The connector is round and may even have a safety clip over it also. Ford didn't want this stuff coming apart accidentally.
Process is staight-forward like you said.
Make sure to relieve the system pressure first.
Remove and replace parts.
Have a vacuum pulled on the system to remove moisture and check for leaks.
Recharge with 134.
I would get a second opinion on the AC problem before you go replacing hundreds of dollars worth of parts. Might be something simple.
Rob
girdnerg is offline
post #13 of 13 (permalink) Old 08-18-2004, 03:20 PM
kingcrab's Avatar
Rob, your advice is invaluable. One other question: How hard is it to remove then replace the belt from the compressor/clutch? I am assuming that it needs to come off and then put back on?
Later,
Joshua
1994 3.8 na
kingcrab is offline
