Underdrive Pulleys - TCCoA Forums
post #1 of 13 (permalink) Old 01-16-2004, 07:58 AM Thread Starter
Send a message via AIM to nidex
Underdrive Pulleys
Will these work on my car? Whats the difference between aluminum ones and steel ones.. which is better?
'94 Thunderbird 4.6L
nidex is offline
post #2 of 13 (permalink) Old 01-16-2004, 08:09 AM
Boom.
Palmguy's Avatar
http://www.steeda.com/store/-catalog/underdrive46.htm
701-0001
You want these. Your link was for 5.0L pullies.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #3 of 13 (permalink) Old 01-16-2004, 09:35 AM Thread Starter
Alright, thanks.
nidex is offline
post #4 of 13 (permalink) Old 01-16-2004, 09:37 AM
I will probably have a set of those available, too...
96 GoldBird
N/A:
96 GoldBird is offline
post #5 of 13 (permalink) Old 01-16-2004, 12:21 PM
T-bird_fan's Avatar
Send a message via Yahoo to T-bird_fan
What is the differences between GT & bullet pulleys?
J-Mod, MMC D/S, 24k gvw Tranny Cooler, Mark VIII TC,13” KVR Frt brakes, FRPP 3.73 rear, PI cams & Intake plus P&P NPI heads with the cooling mod, 1 3/8" Rr swaybar.
T-bird_fan is offline
post #6 of 13 (permalink) Old 01-16-2004, 06:43 PM
RAYBROADWAY's Avatar
Check ebay!
I sniped my MARCH pullies for less than $50 shiped.
K&N FIPK73mm C&L MAF*22C plugs*FRPP 9mm wires*MARCH Performance Pullies*Sprint springs*Cat-back Flowmaster exhaust
95 Front end*SCP Cobra R Hood*93 SC rear bumper "smoothed out"*Ford Racing Cobra R's*OEM spoiler
Idaglo silver gauges w/ blue needles*All black interior with Mark VIII leather seats
RAYBROADWAY is offline
post #7 of 13 (permalink) Old 01-17-2004, 10:28 AM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
I found some specific information for you off the Bullitt owners website...
Bullitt water pulley 5.5 GT 5.0
Bullitt alternator pulley 2.50 GT 2.25
Bullitt crank pulley 6.75 GT 6.75
http://www.imboc.com/phpBB/viewtopic...ic=508&forum=2
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #8 of 13 (permalink) Old 01-18-2004, 08:20 PM Thread Starter
One more thing.. do they come with the belt? If not, where do I get it?
nidex is offline
post #9 of 13 (permalink) Old 01-18-2004, 09:02 PM
Underdrive pullies do not require a different belt. You just use the stock belt, it'll be fine...
96 GoldBird
N/A:
post #10 of 13 (permalink) Old 01-18-2004, 09:32 PM
J.Miller's Avatar
When you do the job check the belt for cracks. If they exist replace it.
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #11 of 13 (permalink) Old 01-18-2004, 09:47 PM
RIP Jake
Leland Jacobson's Avatar
There will be cracks in the belt as all of them are designed to crack some sooner rather than later, except the "Gatorback' which has those diagonal sipes to relieve some stress when the belt gets bent backward on some pulleys... I am trying one on my blower drive and it does seem superior.....
Leland Jacobson is offline
post #12 of 13 (permalink) Old 01-18-2004, 09:53 PM
J.Miller's Avatar
Ah, excessive cracks.
J.Miller
J.Miller is offline
post #13 of 13 (permalink) Old 01-18-2004, 09:53 PM
I should have said "a" stock belt, rather than "your" stock belt, since I don't know the present condition of your belt. What I meant is the stock belt is the right size...
96 GoldBird
N/A:
post #14 of 13 (permalink) Old 01-18-2004, 10:00 PM
I suppose now we have to define "excessive?" Would that be 12, or 17, or 32, or 47 cracks???
If your belt hasn't been slipping or does not appear to be particularly decrepit, chances are it will last a bit longer with the new pullies.. it is not likely that they will speed up the demise of your belt.
On the other hand, they are not particularly expensive (especially through Dan Newman), so replacing your belt as a matter of course would satisfy everyone so concerned.
96 GoldBird
N/A:
post #15 of 13 (permalink) Old 01-19-2004, 06:40 AM
J.Miller's Avatar
For stock belts:
Minor cracks in the V-ground portion of the belt is considered acceptable. If the belt has chunks missing from the ribs, the belt should be replaced.
Conditions requiring belt replacement:
* rib chunk-gut
* excessive wear
* severe grazing
* frayed cords or similar conditions
Replace any belt exhibiting one of the above conditions.
The above is the standard line. I always replaced my belt when the cracks were numerous and close to the backing. This generally occurs when there are many cracks over every inch of the belt. If the belt goes when you are driving you can not go that far.
Can't a guy get lazy every now and then. Happy???
J.Miller
J.Miller is offline
post #16 of 13 (permalink) Old 01-19-2004, 07:45 AM
RIP Jake
Another thought, I always change early, carry a 1/2" ratchet and a cheater bar with me and save the old belt as an emergency spare....Learned this after driving 180 mi in the Fla heat on a weekend with no A/C, P/S, and a draining battery on a Sunday afternoon..... LOL
